Channel 5 catch up
- Everything else
- Channel 5 catch up
Channel 5 catch up
07-12-2017 1:02 PM
Just had a wierd occurance ? i cant watch Channel 5 catch up all other catch up TV work BBC etc
Channel 5 error
Re: Channel 5 catch up
07-12-2017 1:15 PM
Hi @rongtw
I did try and respond to your thread, but the lovely (sic) Lithium software told me off saying this thread is read only. If this post makes it though, I'll try to respond fully.
07-12-2017 1:20 PM
You probably posted your reply just as I was moving the thread.
Forum Moderator and Customer
07-12-2017 1:24 PM - edited 07-12-2017 1:25 PM
Ok that seemed to work.
I'll try again.
Can't remember what I was typing now, but yes it could be at the server side. If you're internet is working fine test it. Then I doubt it'll be your connection. Possibly DNS and routing issues.
Or their servers. Try a different on demand service on another channel and see if it works.
EDIT: Fair enough @Mav just confused me a bit and I lost what I typed. Oh well.
07-12-2017 1:28 PM - edited 07-12-2017 1:29 PM
If I am writing a longish post I tend to hit CTRL-C as a matter of course befoore posting just in case of issues - not just in this forum but others as well.
07-12-2017 1:31 PM
Yep I used too, should still do it. My fault.
Crtl-C, Ctrl-V into Word and spell check it - I need to get back into that habit.
Repeat the procedure bsck and post
