Changing name servers
- Everything else
- Re: Changing name servers
21-12-2007 10:21 PM
Does anyone know how I can change my primary or secondary nameservers?
Message 1 of 3
(1,156 Views)
2 REPLIES 2
21-12-2007 10:57 PM
Is this on your PC or for your domain?
On your PC if windows, right click on network neighbourhood and select properties. Right click on your network connection and select properties. Then select TCP/IP in the main windows and click properties. You can then enter the DNS IPs you want.
If a domain then where is it registered?
Message 2 of 3
(402 Views)
21-12-2007 10:59 PM
It's registered with Plusnet, but the hosting is with Westhost.
Thanks for the speedy reply Peter.
Message 3 of 3
(402 Views)
- Everything else
