Changing hostname on static IP
Jas_T
I see from other posts that it is possible to change the hostname that is made public on a static IP.  Currently it is my Plusnet username but I'd like to have something more anonymous such as my IP address.  I spoke to customer support but they denied knowledge of this.  Can anyone help to implement this change please?  Thanks.
5 REPLIES 5
Tina11192
Fixes: 18
Re: Changing hostname on static IP
Hi @Jas_T I just DM you, please can you provde me with the domain so that i can raise it with NetOps team.
Look forward to hear from you
Cri Ignatti
Fixes: 388
@Tina11192 I think you may have misinterpreted the OPs request - they are asking for their rDNS record to be changed from  <username>.plus.com to <ipaddress>.plus.com
Tina11192
Fixes: 18
Hi @jab1 I'm so sorry I have indeed mi-sread it!
I have now raised this with our NetOps team for you @Jas_T here's a direct link to the question opened on your account: https://www.plus.net/wizard/p=view_question&id=245497321
Cri Ignatti
Jas_T
Thanks very much Cri.  Unfortunately the link doesn't open for me but hopefully I'll get a response from the team when they look at it.  Much appreciated.
Fixes: 1,495
Corrected link is https://www.plus.net/member-centre/login?p=view_question&id=245497321
