Changing Static IP
mason64
Changing Static IP
Hey,
how do i change my static ip. i have it for a few years now and want to renew it with another IP if possible. I still want to keep a static ip but want to change what the address is to another one.
Thank You
Dave
Tags (2)
6 REPLIES 6
Fixes: 1,482
Re: Changing Static IP
Moderators Note
This topic has been moved from Fibre to Everything Else
gt0872
I need the same thing. I want to change my ip address, but I can't.
There is a "Configure Static IP" link/button - that doesn't work.
Fixes: 1,599
Thanks for getting in touch.
I've raised support tickets onto your accounts you can make your requests on.
@mason64 the ticket's Here and @gt0872 it's Here. I hope this helps.
Bojang1
In your account under add ons select delete static IP. Once deleted you can request a new one which will cost £5 (one off fee). The new IP should be working within minutes.
😮NOTE TO ALL> When you use a plusnet static IP they will add your username the the IP address. I think this is a massive breach of privacy!! And they do not tell you that they have done it. It's fine if your account name is ABC123 but a lot of users may use there real name or age within the account name. So if you have a static IP from plusnet you can be very accurately be personalised when searching on the internet. If you ask Plusnet they will anonymise the IP address with the word plus.com at the end rather than your name.
Bojang1
Once you have read the notice warning above please click LIKE so it stands out for other users to read. 👇
Bojang1
Forgot to say.... If you want to check it visit this website whatismyipaddress.com/ip/
and enter your plusnet static IP address at the end of the the last trailing /
You will then see your plusnet username which can be traced back to your account here. Try IT
