Change to new BTw Speedtest & BTw DSL Checker
- Everything else
- Change to new BTw Speedtest & BTw DSL Checker
19-04-2020 8:52 PM
You might noticed that BTw has changed new site for BTw speedtest and BTw dsl checker.
For fetching bras ip profile rate - Click go for speedtest then click Additional Diagnostic then click 'I have a Fibre to the Premises Broadband' to enter your telephone number and wait for the page reload itself for your bras ip profile on your line.
Click here: https://speedtest.btwholesale.com/
Bras IP Profile
Here is new BTw dslchecker click here: https://www.broadbandchecker.btwholesale.com/#/ADSL
BTw DSL Checker
Re: Change to new BTw Speedtest & BTw DSL Checker
19-04-2020 9:19 PM
Typical BTw they have their Additional diagnostics options the wrong way around, selecting FTTC tries an FTTP test and the FTTP test is what gives the FTTC results.
19-04-2020 9:48 PM
The initial speed test appears to be giving better (faster) results.
Customer and Forum Moderator. Windows 10 Firefox 101.0.1 (64-bit (64-bit)
19-04-2020 9:59 PM
This topic has been moved from Fibre Broadband to Everything Else.
19-04-2020 10:30 PM
The speed test does appear to give the correct results which it hasn't done for a while now, they just need to put the correct further diagnostic tests with the correct options.
19-04-2020 10:46 PM
The 'clean' and 'impacted' VDSL figures for my line seem optimistic compared to the old format.
FTTC 40/10 Billion 8800NL
BT technician (Retired)
20-04-2020 7:25 AM
I'm intrigued by the Max observed speeds? Mine show 68 down and 17 up, but I'm on a 40/10 connection. I That limits the sync speeds , so how does it observe speeds above that ?
20-04-2020 11:15 AM
@MisterW I believe it's based on the max attainable rate reported by the router. A check on my parents line who are on 40/10 but could get 80/20 shows the same
20-04-2020 11:24 AM
@MatthewWheeler thanks, I guessed it might be using that.
28-04-2020 3:24 PM - edited 28-04-2020 3:25 PM
Seems BTw have fixed the Additional Diagnostic selection options, picking FTTC now goes to the correct tester and same for FTTP.
28-04-2020 4:53 PM
No, they haven't fixed it yet (upload speed and ping are incorrect) need more work on it
28-04-2020 10:17 PM
I wasn't talking about the Tester itself I was talking about the Additional diagnostic options that were the wrong way around being fixed.
- Everything else
