Change to new BTw Speedtest & BTw DSL Checker
Fixes: 8
You might noticed that BTw has changed new site for BTw speedtest and BTw dsl checker.
For fetching bras ip profile rate - Click go for speedtest then click Additional Diagnostic then click 'I have a Fibre to the Premises Broadband' to enter your telephone number and wait for the page reload itself for your bras ip profile on your line.
Click here: https://speedtest.btwholesale.com/
Bras IP ProfileBras IP Profile
Here is new BTw dslchecker click here: https://www.broadbandchecker.btwholesale.com/#/ADSL
BTw DSL CheckerBTw DSL Checker
11 REPLIES 11
Re: Change to new BTw Speedtest & BTw DSL Checker
Typical BTw they have their Additional diagnostics options the wrong way around, selecting FTTC tries an FTTP test and the FTTP test is what gives the FTTC results.
Fixes: 459
The initial speed test appears to be giving better (faster) results.
Customer and Forum Moderator. Windows 10 Firefox 79.0 (64-bit)
Fixes: 459
Moderators Note
This topic has been moved from Fibre Broadband to Everything Else.
The speed test does appear to give the correct results which it hasn't done for a while now, they just need to put the correct further diagnostic tests with the correct options.
Fixes: 24
The 'clean' and 'impacted' VDSL figures for my line seem optimistic compared to the old format.
Behind every successful man is a surprised woman
Fixes: 129
I'm intrigued by the Max observed speeds? Mine show 68 down and 17 up, but I'm on a 40/10 connection. I That limits the sync speeds , so how does it observe speeds above that ?
Fixes: 388
@MisterW I believe it's based on the max attainable rate reported by the router. A check on my parents line who are on 40/10 but could get 80/20 shows the same
 Matthew Wheeler
Fixes: 129
@MatthewWheeler  thanks, I guessed it might be using that.
Seems BTw have fixed the Additional Diagnostic selection options, picking FTTC now goes to the correct tester and same for FTTP.
Fixes: 8
No, they haven't fixed it yet (upload speed and ping are incorrect) need more work on it
I wasn't talking about the Tester itself I was talking about the Additional diagnostic options that were the wrong way around being fixed.
