Change to new BTw Speedtest & BTw DSL Checker
goldenfibre
Seasoned Pro
Fixes: 12
You might noticed that BTw has changed new site for BTw speedtest and BTw dsl checker.
For fetching bras ip profile rate - Click go for speedtest then click Additional Diagnostic then click 'I have a Fibre to the Premises Broadband' to enter your telephone number and wait for the page reload itself for your bras ip profile on your line.
Click here: https://speedtest.btwholesale.com/
Bras IP ProfileBras IP Profile
Here is new BTw dslchecker click here: https://www.broadbandchecker.btwholesale.com/#/ADSL
BTw DSL CheckerBTw DSL Checker
11 REPLIES 11
Terranova667
Fixes: 5
Re: Change to new BTw Speedtest & BTw DSL Checker
Typical BTw they have their Additional diagnostics options the wrong way around, selecting FTTC tries an FTTP test and the FTTP test is what gives the FTTC results.
Strat
Fixes: 565
The initial speed test appears to be giving better (faster) results.
Strat
Fixes: 565
Moderators Note
This topic has been moved from Fibre Broadband to Everything Else.
Terranova667
Fixes: 5
The speed test does appear to give the correct results which it hasn't done for a while now, they just need to put the correct further diagnostic tests with the correct options.
198kHz
Fixes: 41
The 'clean' and 'impacted' VDSL figures for my line seem optimistic compared to the old format.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Fixes: 393
I'm intrigued by the Max observed speeds? Mine show 68 down and 17 up, but I'm on a 40/10 connection. I That limits the sync speeds , so how does it observe speeds above that ?
MatthewWheeler
Fixes: 479
@MisterW I believe it's based on the max attainable rate reported by the router. A check on my parents line who are on 40/10 but could get 80/20 shows the same
 Matthew Wheeler
Fixes: 393
@MatthewWheeler  thanks, I guessed it might be using that.
Terranova667
Fixes: 5
Seems BTw have fixed the Additional Diagnostic selection options, picking FTTC now goes to the correct tester and same for FTTP.
goldenfibre
Seasoned Pro
Fixes: 12
No, they haven't fixed it yet (upload speed and ping are incorrect) need more work on it
Terranova667
Fixes: 5
I wasn't talking about the Tester itself I was talking about the Additional diagnostic options that were the wrong way around being fixed.
