Ccgi webspace - can't log in
madgav
Hi
I'm trying to access my ccgi webspace for the first time in a long time and the password won't work with either Filezilla or hosting.plus.net
I'm absolutely sure that the password was the same as my plusnet login. But it's not working.
I tried the password reset on hosting.plus.net, but three attempts later and the password reset email hasn't arrived in any of my mailboxes.
Wonder if any of the support guys could reset this for me? I'm trying to back up everything prior to (hopefully) getting FTTP upgrade tomorrow.
Gavin.
16 REPLIES 16
bobpullen
Fixes: 330
Re: Ccgi webspace - can't log in
What username are you entering during the password reset process?
It needs to be in the same format as the CGI HTTP address, e.g. 'ccgi.<username>.plus.com'.
Also of note is that the FTP password is separate to the hosting.plus.net login so if you have forgotten that too, then you may need to change it once logged into the Control panel.
madgav
Thanks Bob, yes I've been using the username in that format.
I didn't know the two passwords were separate, looks like both may need reset!
Gavin.
bobpullen
Fixes: 330
I've triggered a Hosting Portal password reset from the back-end system. It's seemingly been sent to the email address associated with your Plusnet account. Let me know if you don't receive it and I'll think of another method.
madgav
Thanks Bob, I haven't received the email though. I'll PM you another email address.
bobpullen
Fixes: 330
Have taken a different approach and dropped you another PM. let me know how you get on.
madgav
Hi Bob
Thanks for that, just to confirm I now have access to both the control panel and FTP, and have changed the passwords on both.
Many thanks again for your help 👍
Regards
Gavin.
Real_Grizzly
Since Sep 2022I I also have this problem, although I have had and used my CCGI space for about 17 years, I hadn't updated for a while but when I tried I could not login (via ftp client) I phoned many times but was told no-one could help me, or to wait for a password reset link to come, when I mentioned I had tried that with no result I was again told that no-one could help "Until" I had the reset link (catch 22)
Please help as I really need to update my site
bobpullen
Fixes: 330
@Real_Grizzly - what username are you entering in the password reset field at https://hosting.plus.net? It typically needs to be in the format ccgi.<username>.plus.com
Real_Grizzly
Since Sep 2022 I have not been able to upload content to my CCGI space, I have phoned support many times with no help, I tried the password reset option (even though I know it was correct) but not no post / link, support (via phone) claimed that unless I had that link they could not help, (catch 22) I not getting the link post (a problem) but they cant help with that until I do
Please someone help
Real_Grizzly
I used ccgi.grizzlyadams.plus.com as user name
bobpullen
Fixes: 330
Thanks. I think I see what's going wrong with the system-generated reset emails.
I've just dropped an email to the contact address on your account. Hopefully it helps.
Real_Grizzly
I did get that, where would I find FTP Manager? I tried via the CGI Space icon but that only sent me to
https://hosting.plus.net/portal/
where I cannot login
Sorry if I'm just having a senior moment maybe a link would help
bobpullen
Fixes: 330
@Real_Grizzly - the details I emailed to you will allow you to log into the the control panel at https://hosting.plus.net
The FTP Manager is found by navigating through that site once logged in.
Real_Grizzly
But I cannot log in to https://hosting.plus.net that is the problem it reports
Incorrect username or password.
an dso far (since Sep 2022) I don't had any post with a reset link, but I have just tried that again
