Cant Connect to my website via FTP program
- Everything else
- Cant Connect to my website via FTP program
09-03-2008 11:47 AM
I seem to be unable to set up an FTP connection to my webspace (using FireFTP)
To connect I do the following :
I set (FireFTP) or (IE7) to point at ftp.plus.net
use my username : jonjoyce
and then my password for the main Plus-net site.
I am getting an login incorrect error - unable to make a connection.
Is there a problem with my webspace or am I connecting incorrectly
Re: Cant Connect to my website via FTP program
09-03-2008 12:27 PM
09-03-2008 12:30 PM
Been having problems connecting since then , but been trying to work out if the problem is on my side !
09-03-2008 1:54 PM
09-03-2008 2:51 PM
I enter the details and the box then reappears with the details blanked out , i don't receive an error message at all .
09-03-2008 2:59 PM
09-03-2008 3:19 PM
It just seems a bit bizzare that my broadband and email etc.. are all OK with the same password
09-03-2008 5:58 PM
Im struggling to find out what im doing wrong to be honest !
09-03-2008 6:29 PM
09-03-2008 7:01 PM
So I should change my password and maybe try again ?
Is this something worth raising as a fault ?
Cheers
09-03-2008 9:11 PM
10-03-2008 8:57 AM
10-03-2008 12:32 PM
Thanks for everyone's help
- Everything else
