Cannot connect to my webspace via FTP this morning?
- Everything else
- Cannot connect to my webspace via FTP this morning...
28-07-2014 8:07 AM
Just to be clear I can connect to the Internet etc, and the FTP is just timing out without connecting. Looking at my logs I see there have been problems with FTP on an off all this morning.
Any help appreciated, perhaps I need to raise a ticket?
Re: Cannot connect to my webspace via FTP this morning?
28-07-2014 11:27 AM
28-07-2014 11:43 AM
Just in case I restarted my FTTC modem earlier and left things while I was out.
I noticed that occasionally a transfer from my webcam got through to my weather Web site hosted on PN, and that a PC that uploads some data to that Web site also is lagging behind a lot, only updating it last at 09:50.
I still cannot connect to my webspace via FTP, it just times out. Normally everything is very snappy here on FTTC, and I have changed nothing since it was all working last evening.
I may try and see if I can connect by using my 3G phone as a hotspot as a test now.
28-07-2014 11:48 AM
Something odd with the routing perhaps via the PN network. I will switch off my airport router and the Modem for a few minutes and see if that clears it.
28-07-2014 12:09 PM
28-07-2014 12:19 PM
All I get from the FTP log is
Could not read reply from control connection -- timed out. (SReadline 1)
Cannot recover from miscellaneous open error -193.
28-07-2014 12:22 PM
28-07-2014 12:29 PM
28-07-2014 12:31 PM
28-07-2014 12:49 PM
ftp ftp.plus.net
Trying 212.159.9.91...
Connected to ftp.plus.net.
That's all I get...
28-07-2014 1:06 PM
I need a fixed IP here, so cannot change it, except by using an alternative network like my O2 3G.
Hope you have enough clues to find this problem. Odd it only stated today, I initially thought it was some scheduled maintenance that had overrun and it would fix itself. Even odder is that a few times today some of my uploads from the weather station have got through, but very rarely.
28-07-2014 1:17 PM
What results do you get if you
1. Ping the site
2. Tracert
28-07-2014 1:36 PM
I also see connection closed by host messages in my log from my weather station on the linux box:
Jul 28 13:00:23 meteohub-rpi logger: ncftpput: cannot open ftp.plus.net: remote host closed control connection.
Jul 28 13:07:53 meteohub-rpi logger: Remote host has closed the connection.
Jul 28 13:09:08 meteohub-rpi logger: Remote host has closed the connection.
Jul 28 13:10:23 meteohub-rpi logger: Remote host has closed the connection.
28-07-2014 1:49 PM
The former works OK, the latter seems to be broken.
28-07-2014 2:03 PM
Connected to 212.159.8.91.
220-PLEASE NOTE: If you have a non-subscription account you
220-will only be able to login to this ftp server if you are
220-dialled into our network.
220-
220-A Maximum of 4 concurrent connections are allowed to this
220-server, each session is limited to 256KB/s downloads.
220-
220 Plus.Net FTP Server #1 ready
Name (212.159.8.91:david):
ftp 212.159.9.91
Connected to 212.159.9.91.
421 Service not available, remote server timed out. Connection closed.
- Everything else
