Cannot connect to host via filezilla [Solved] now other CMDPrompt issues
- Everything else
- Re: Cannot connect to host via filezilla
29-01-2014 6:54 AM
With my previous ISP I had no problem connecting to my host @ http://one.com
For a while I had been using the hosts online file manager for light modifications as its not great at full D/load > back up to HDD or external media thats where Filezilla comes in handy.
I keep getting connection lost
[code=txt file=Conection with server closed prematurely]Connecting to probe.filezilla-project.org
Response: 220 FZ router and firewall tester ready
USER FileZilla
Response: 331 Give any password.
PASS 3.5.3
Response: 230 logged on.
Checking for correct external IP address
IP XXX.XX.XXX.XX1 xxx-xx-xx-xxx
Response: 200 OK
PREP 53442
Response: 200 Using port 53442, data token 1903877656
PORT 46,208,128,181,210,114
Connection lost
Connection closed
[/code]
Edit:
My host seemed to think I was not using Filezilla client after I provided proof
[code=txt file=Transcript of online chat with host]Hyla: Thank you for using One.com 24/7 Interactive Online Support. My name is Hyla. How may I assist you?
you: Hi Hyla
Hyla: Hello there
you: What is the port number to via Filezilla (so used to your new file manager I forgot)
Hyla: Please use ftp port 21
you: Filezilla is saying it could not parse server address, invalid port given
Hyla: Can you please make sure that you are using filezilla client and not the filezilla server ?
Hyla: You can download filezilla client here instead"
Hyla: https://filezilla-project.org/download.php
you: Yes I am using 3.5.3 fileziller client
you: FileZilla Client ---------------- Version: 3.5.3 Build information: Compiled for: i586-pc-mingw32msvc
Compiled on: x86_64-unknown-linux-gnu Build date: 2012-01-08 Compiled with: i586-mingw32msvc-gcc (GCC) 4.2.1-sjlj (mingw32-2)
Compiler flags: -g -O2 -Wall -g -fexceptions Linked against: wxWidgets: 2.8.12 GnuTLS: 2.10.4 Operating system:
Name: Windows Vista (build 6002, Service Pack 2) Version: 6.0 Platform: 32 bit system
you: which I have used many times before but not now
Hyla: Can you please check that you ftp passive mode is enabled in filezilla ?
you: sure ill see if I can locate it
Hyla: okay
you: Its set to passive with the fallback to other transfer mode on failure (ticked)
you: on the next page it says use servers IP address instead or fallback to active mode
Hyla: I think you are not using filezilla client
you: I recently change ISP could it be a closed port issue ?
you: From the Help > copy to clipboard > paste in here > FileZilla Client ---------------- Version: 3.5.3 Build information:
Compiled for: i586-pc-mingw32msvc Compiled on: x86_64-unknown-linux-gnu Build date: 2012-01-08
Compiled with: i586-mingw32msvc-gcc (GCC) 4.2.1-sjlj (mingw32-2) Compiler flags: -g -O2 -Wall -g -fexceptions
Name: Windows Vista (build 6002, Service Pack 2) Version: 6.0 Platform: 32 bit system [/code]
That was when I gave up and closed the chat as I should not have to provide proof twice within a short chat and realised I was not going to get anywhere fast
USER FileZilla
PASS 3.5.3
Response: 200 OK
PREP 53442
Connection lost
Connection closed
[/code]
Edit:
you: Hi Hyla
Hyla: Hello there
Hyla: okay
Message 1 of 7
(8,918 Views)
6 REPLIES 6
29-01-2014 7:56 AM
This is going to be a setting at your end (and this thread should really be in Windows Software?) PN do not block access...
Can you open an ftp connection manually ie type "ftp <hostname>,one.com" at a command prompt? You've posted the dialogue from a connection to probe.filezilla.org - Can you post the log for connecting to your host?
Message 2 of 7
(2,923 Views)
29-01-2014 2:33 PM
in CMD Prompt
[code=txt file=From CMD Prompt]Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved
C:\Users\Comp1>ftp torfaenpcrepair.com
> ftp: connect :Connection timed out
ftp> open torfaenpcrepair.com
ftp>
[/code]
I have tried CMD Prompt with elevated privileges and same result
I have been able to access it from a browser window and type my username / password and can see and access the files
I can Ping the FTP server without issue(s)
No issue(s) with tracert FTP
FileZilla is not giving me any log(s)
ftp>
[/code]
Message 3 of 7
(2,923 Views)
29-01-2014 2:40 PM
Times out from here as well, as does ftp://torfaenpcrepair.com in a browser...
What URL works for you in a browser?
A thought, from another thread - Have you got the firewall turned on in the PN Member Centre?
Message 4 of 7
(2,923 Views)
29-01-2014 5:23 PM
in google chrome browser it is
ftp://ftp.torfaenpcrepair.com
It turned out to be a bad update to FileZilla after uninstalling / re-installing it now works
My bad I had not tested it since it was last updated
However still have the same issue in CMD Prompt so half solved
PlusNets online FireWall is turned on in both Basic & Advanced are set to Low
In the Advanced Low does block Ports 20, 21
However I can now use Filezilla to connect but not CMD Prompt ?
Edit:
Fixed broken URL
Low
Block all incoming traffic to ports that are often abused. These include ports 20, 21, 25, 80, 111, 135, 137, 138, 139, 445, 515, 1080, 1433, 3128, 3306, 6000, 8080. Find out more
Edit:
Fixed broken URL
Message 5 of 7
(2,923 Views)
29-01-2014 5:39 PM
If you changed the Plusnet firewall settings did you do a disconnect/connect in your router to activate the change?
Message 6 of 7
(2,923 Views)
29-01-2014 5:55 PM
I have changed the Advanced setting to off for testing
Disconnected via the router GUI and hit a snag
It took me straight to the login page and will not allow me to log back in to Reconnect
Switched router Off / On now able to connect to internet
However
Lost access to Router GUI
Going to try a telnet
Telnet comes back Invalid UserName/Password
Closing connection
Will factory reset the router and edit report
After a factory reset
I can access the router GUI
Telnet into router
but
Still can not not access my site via CMD FTP
tried the Disconnect / Reconnect
& stops me from logging back into the router GUI and Telnet
Any attempts to access any webpages takes me to the router login page until I either turn router Off / On or Factory reset the Router
Thus preventing me from using the Disconnect / Reconnect facility
Can we safely say that I have 2 dodgy routers ?? see my other thread in Broadband and Routers
However
Closing connection
Telnet into router
but
Message 7 of 7
(2,923 Views)
- Everything else
