Can user name be changed?
- Everything else
- Re: Can user name be changed?
14-08-2007 7:55 AM
Can user name be changed please? I have spelling errors in mine, which I shall not be able to remember. Either drunk or typos,
and I would very much like to change the spelling or the name entirely.
Many thanks
Many thanks
Message 1 of 9
(4,593 Views)
8 REPLIES 8
14-08-2007 10:19 AM
Is this your forum username or your main account username?
If it's your forum name then you can simply use this link to change the display name.
If it's your main account name then this is a far more tricky beast to do.
Message 2 of 9
(1,341 Views)
14-08-2007 5:02 PM
Thanks for the link Chris, but it wasn't liked I turned up an error page and then I lost PN altogether!!
So I shall just have to try to remember my silly typo then
Message 3 of 9
(1,341 Views)
14-08-2007 5:03 PM
If you want to PM me what you want it changing to, I'll sort the display name out for you.
Message 4 of 9
(1,341 Views)
14-08-2007 7:29 PM
A bit puzzled.
If I go to http://community.plus.net/forum/index.php?action=profile;sa=account it would appear that the display name may be modifiable.
No - I am not going to try.
Edit - link made general
Message 5 of 9
(1,341 Views)
14-08-2007 9:28 PM
I can confirm the display name is modifiable. I know because that over there <--- is not my username
Message 6 of 9
(1,341 Views)
15-08-2007 10:03 AM
I know what I've done ;), I linked you to my profile and that caused the problem. Try this link instead.
Message 7 of 9
(1,341 Views)
15-08-2007 10:16 AM
Anyone can update their own display name, however I've said in a previous reply that I'd be happy to do it from a PM
Message 8 of 9
(1,341 Views)
15-08-2007 11:51 AM
Works for me too James, you can actually remove the variable for u completely like this.
Message 9 of 9
(1,341 Views)
- Everything else
