Can't run the BT Speedtester - flash not supported in my browser
- Everything else
- Can't run the BT Speedtester - flash not supported...
09-06-2017 2:43 PM
so what are the alternatives
Re: Can't run the BT Speedtester - flash not supported in my browser
09-06-2017 2:46 PM
Is this any use to you @Oldjim
09-06-2017 2:56 PM
not if I want to raise a fault or check my IP Profile
if I just want speed test I use the TBB one
09-06-2017 3:06 PM
You can check your IP profile here.
09-06-2017 3:16 PM - edited 09-06-2017 3:32 PM
interesting but very odd - it reports this
The current Downstream BRAS rate is: 50.17 Mbps
The current Upstream BRAS rate is: 20 Mbps
but my sync speed is 54.19
this would explain the rather low speed test results
09-06-2017 3:28 PM
That tool reports my d/s BRAS as 8.53 - as does the BT test, but RSL reports my connection speed as 9.67
09-06-2017 3:34 PM
88.2% for ADSL is fine according to Kitz, Jim's profile is rather odd though.
09-06-2017 4:43 PM
Install chrome and just use it for the BT speedtest
10-06-2017 9:46 AM
can you run a GEA Test on my line please
10-06-2017 10:07 AM
GEA test below
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0003 |
Description | No problem found, OAM test is not currently supported on this line. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 51.8 Mbps |
Upstream Speed | 10.1 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 730.7 |
Upstream Rate Assessment | Reasonable |
Downstream Rate Assessment | Good |
Interference Pattern | Regular Interference Observed Daily |
Service Impact | No Impact Observed |
Interference Duration Longest Occurrence | ; 00:00 to 23:45 |
Interference Location | Customer Premise |
Interference Observed In Days | 14 |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2017-05-28T10:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 48.3 Mbps | 54.1 Mbps | 50.2 Mbps |
Up Stream Line Rate | 7.6 Mbps | 11.0 Mbps | 8.5 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 896.9 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2017-06-10T08:36:54Z | 2017-06-10T08:51:54Z |
Ingress Code Violation | 64 | 57 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
10-06-2017 11:30 AM - edited 10-06-2017 11:32 AM
thanks @MatthewWheeler interesting the reported downstream speed is less than that reported by the router which is apparently a function of the retransmission high setting
also how do they decide that there is regular interference on the customers premises
I agree that there is constant interference but this is down to the very low noise margin of 1.4dB downstream and 2.8dB upstream showing up on the FEC errors
downstream about 13000 FEC per minute and upstream about 300 FEC per minute
I suspect that a resync may be called for
10-06-2017 1:48 PM
10-06-2017 3:40 PM
done a resymc
Connection speed (kbps): 50149 8004
SNR margin (dB): 3.4 6.2
IP Profile now about 46 so will see how long before the DLM reacts as the FEC errors have dropped drastically
- Everything else
