Can't run the BT Speedtester - flash not supported in my browser
Oldjim
Resting Legend
Fixes: 63
so what are the alternatives
12 REPLIES 12
Re: Can't run the BT Speedtester - flash not supported in my browser
Is this any use to you @Oldjim
http://www.meter.net/
Oldjim
Resting Legend
Fixes: 63
not if I want to raise a fault or check my IP  Profile
if I just want speed test I use the TBB one
Browni
Aspiring Hero
Fixes: 60
You can check your IP profile here.
Oldjim
Resting Legend
Fixes: 63
interesting but very odd - it reports this
The current Downstream BRAS rate is: 50.17 Mbps
The current Upstream BRAS rate is: 20 Mbps
but my sync speed is 54.19
this would explain the rather low speed test results
Legend
Fixes: 255
That tool reports my d/s BRAS as 8.53 - as does the BT test, but RSL reports my connection speed as 9.67
Browni
Aspiring Hero
Fixes: 60
88.2% for ADSL is fine according to Kitz, Jim's profile is rather odd though.
SpendLessTime
Fixes: 86
Install chrome and just use it for the BT speedtest
Oldjim
Resting Legend
Fixes: 63
@MatthewWheeler
can you run a GEA Test on my line please
MatthewWheeler
Fixes: 479
GEA test below
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 51.8 Mbps
Upstream Speed 10.1 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 730.7
Upstream Rate Assessment Reasonable
Downstream Rate Assessment Good
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ; 00:00 to 23:45
Interference Location Customer Premise
Interference Observed In Days 14
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2017-05-28T10:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 48.3 Mbps 54.1 Mbps 50.2 Mbps
Up Stream Line Rate 7.6 Mbps 11.0 Mbps 8.5 Mbps
Up Time 0.0 Sec 900.0 Sec 896.9 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2017-06-10T08:36:54Z 2017-06-10T08:51:54Z
Ingress Code Violation 64 57
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Matthew Wheeler
Oldjim
Resting Legend
Fixes: 63
thanks @MatthewWheeler interesting the reported downstream speed is less than that reported by the router which is apparently a function of the retransmission high setting
also how do they decide that there is regular interference on the customers premises
I agree that there is constant interference but this is down to the very low noise margin of 1.4dB downstream and 2.8dB upstream showing up on the FEC errors
downstream about 13000 FEC per minute and upstream about 300 FEC per minute
I suspect that a resync may be called for
MatthewWheeler
Fixes: 479
If I'm honest I'm not 100% sure.
The data used to determine it is on Openreachs end and we can't see it.
 Matthew Wheeler
Oldjim
Resting Legend
Fixes: 63
done a resymc
Connection speed (kbps): 50149 8004
SNR margin (dB): 3.4 6.2
IP Profile now about 46 so will see how long before the DLM reacts as the FEC errors have dropped drastically
