Can't reach NS&I login page
Fixes: 526
Re: Can't reach NS&I login page
am not convinced it is a 'Plusnet' issue - I can't access it over my Zen connection, either, although I can reach the login page via the 'home' NS&I  site. Don't know if you can login from there - I don't have an NS&I account to try.”
@Champnet to confirm , secure.nsandi.com is not accesible from a Zen connection. Going to the login page via nsandi.com does allow login from a Zen connection ( I do have an NS & I account!). Going to the login page via nsandi.com from a PN connection (80.229... static IP) results in it timing out.
@bobpullen  also confirmed earlier that secure.nsandi.com doesnt work from an EE connection either.
Like you, I'm a bit surprised , given the above, that its not all over the internet ?
Champnet
Fixes: 18
@jab1 I don’t think it’s a DNS problem, I would suspect a security issue but again you’re the exception.
I thought maybe a routing table fault but how can you program a rule that covers Plusnet customers and one Zen customer using the Openreach infrastructure ?
Anyone else on Openreach but not a Plusnet customer having problems ?
Fixes: 334
@RobK It is NOT just Plusnet - as has been said above, I can't go direct to the 'secure.nsandi' site, but can reach the login page if I go via their homepage. The issue is somewhere deeper in the routing.
Fixes: 334
@MisterW  Thanks.
Not that it should matter, but is your Zen connection IPV4 or 6?
Champnet
Fixes: 18
@jab1  Apologies, seems you’re not the only exception……..
jgb
Champion
Fixes: 22
I have just rechecked and I can reach the NS&I login / register page either directly or via their home page. I am on Zen but unlike others here I am on the City Fibre network. I am using W11 and Edge. Also works on Chrome. IP4 connection. Thus, is the problem confined to trying from the Openreach network?
Champnet
Fixes: 18
Thanks, I think you've just confirmed it is................
Fixes: 334
Strange, @jgb . As I said, my only connection with BT/OR is the wires - Zen don't touch the BT network on a 'transport' level at all.
Fixes: 526
@jab1 yes they do, they still use BTwholesale for many of their connections. Only the City Fibre ones avoid BT completely
jgb
Champion
Fixes: 22
As I said I am on Zen but with a City Fibre connection; no BT Openreach wires or fibre at my end. However I am ignorant of whether or not City Fibre interact / connect with the Openreach network somewhere down the line.
As @jab1 says Zen do use Openreach where City Fibre is not available. They used to do so around here up until a few months ago when City Fibre went live her (and Zen's prices dropped!!)
Fixes: 334
Interesting @MisterW  I'll do an MTR check to bbc.co.uk and see what route I get - in a short while, got a couple of other things to do first. 😉
Fixes: 334
I've 12 months or so before I'm in that lucky position. 😉
Fixes: 334
@MisterW my MTR never seems to complete - I get so far and then it just hangs - various numbers of hops, but never seems to reach the destination. Although I can always get to the sites in the normal way.
pvmb
Fixes: 7
Is it spreading?
User reports indicate possible problems at NS&I (National Savings)
https://downdetector.co.uk/status/nsi/
NS&I (National Savings) outages reported in the last 24 hours
Later: Now showing no problems again! 🤔
Later Still: Problems again!  What's going on?
pvmb
Fixes: 7
I can only get to here:
>pathping secure.nsandi.com
Tracing route to secure.nsandi.com [157.203.60.156]
over a maximum of 30 hops:
0 Lizard.home [192.168.1.65]
1 192.168.1.254
2 250.core.plus.net [195.166.130.250]
3 * * *
Computing statistics for 50 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
0/ 100 = 0% |
1 0ms 0/ 100 = 0% 0/ 100 = 0% 192.168.1.254
0/ 100 = 0% |
2 5ms 0/ 100 = 0% 0/ 100 = 0% 250.core.plus.net [195.166.130.250]
Trace complete.
