Can't reach NS&I login page
Clarissa
Re: Can't reach NS&I login page
Thanks Rob
That is probably good advice
Bless you!
Clarissa
Correct
I can reach the NS&I home page (https://www.nsandi.com) and read all about their products and services, but as soon as I click the Login button, which is supposed to take you to https://secure.nsandi.com, the connection is interrupted and I get the message that the site has taken too long to respond, and I should contact my ISP.
Legend
Fixes: 289
Strange, @Clarissa  - I can get the login page if I go via the homepage.
j_s
I also have this exact issue. I did speak to support but didn't really have any luck. Hopefully, the Plusnet guys will see that this is not isolated and get it sorted.
Clarissa
I do hope so
Mav
Fixes: 518
Moderator's note(s):
Thread moved from My Router to Everything Else.
Also a redirect from https://community.plus.net/t5/Full-Fibre/Login-for-nsandi-com-won-t-respond/m-p/1977076 which I have locked in favour of this thread.
Forum Moderator and Customer
Mav
Fixes: 518
Same issue here using any of the suggestions above.
No issue reaching the Log In page if using a VPN.
beeceegee
Fixes: 4
As others have reported
I can log in via PN only if I have a VPN connection active (laptop or iphone); I can also log in on my iphone using the mobile connection.
AndrewD1
Hi Clarissa, I've been experiencing the same issue. Spoke to support (Matthew, very helpful thanks!).
I had a fixed IP address on my account and that seemed to be causing the problem. I don't need it so removed it from the account and that's sorted it.
Alternatively use a VPN, Matthew suggested using the Opera browser with built in VPN which worked too as a workaround before we got rid of the fixed IP.
Champnet
Aspiring Hero
Fixes: 15
Hard to believe all these denied users have fixed IPs.......
Fixes: 447
Well I certainly can't reach it from a dynamic IP!
My home connection is a static but I'm on holiday and by chance the apartment has a Plusnet connection , dynamic in the 87.115... subnet
Fixes: 90
I have a static IP address 80.229.xxx.xxx and I cannot login into my NS&I account , fortunately the NS&I app works so I was able to check I am not a winner this month.
I see a syn_sent when attempting to login "TCP    192.168.10.100:53142   157.203.60.156:443     SYN_SENT"
Edit: corrected IP Address
Fixes: 447
and to confirm what @jab1 reported earlier, it doesnt work from a Zen connection either.
Tried VPN to the Office which is on a block of Zen static IPs.
Looks like its affecting most (if not all) of the BT network ?
Fixes: 90
To add a MTR reveals
  1. AS???    192.168.10.1                               0.0%    10    1.0   1.1   0.9   1.5   0.2
  2. AS6871   254.core.plus.net                          0.0%    10    7.5   7.6   7.2   8.3   0.3
  3. AS6871   84.93.253.115                              0.0%    10    8.2   8.3   7.9   8.6   0.2
  4. AS2856   195.99.125.134                             0.0%    10    7.8   8.1   7.7   8.6   0.2
  5. AS2856   core6-hu0-7-0-26.faraday.ukcore.bt.net     0.0%    10    8.1   8.1   7.6   8.3   0.2
  6. AS2856   core2-hu0-15-0-4.colindale.ukcore.bt.net   0.0%    10    9.0   8.9   8.4   9.3   0.2
  7. AS2856   acc3-hu0-9-1-0.colindale.ukcore.bt.net     0.0%    10    9.2   9.3   9.0   9.8   0.3
  8. AS2856   217.38.123.105                             0.0%    10   11.4  11.8  11.1  13.8   0.8
  9. AS???    Huh                                       100.0    10    0.0   0.0   0.0   0.0   0.0
AS6871 are plusnet IP's; AS2856 are BT IP's
Mr_Paul
Seasoned Pro
Fixes: 12
@MisterW wrote:
"and to confirm what @jab1 reported earlier, it doesnt work from a Zen connection either.
Looks like its affecting most (if not all) of the BT network ?"
I'm confused:
It appears to me that for all Plusnet users, https://secure.nsadndi.com does not work, but some of us, myself included, can log in via NS&I's home page? However, for some, eg @Clarissa, that does not work either?
What might cause that difference between PN customers?
Do Zen have some sort of connection with the BT network?
