Can't reach NS&I login page
- Everything else
- Re: Can't reach NS&I login page
15-07-2024 6:04 PM
The secure section of a financial institute is never going to respond to a ping or any similar network check.
15-07-2024 6:53 PM
I was trying to log into my NS&I account today and came across this problem.
After searching, I found this article on the Express website:
https://www.express.co.uk/finance/personalfinance/1923359/premium-bonds-nsi-nsandi-Plusnet
which specifically mentions Plusnet.
15-07-2024 6:58 PM
@RichT It may have 'specifically' mentioned Plusnet, but they are not the only ISP involved.
15-07-2024 7:14 PM - edited 15-07-2024 7:16 PM
I doubt if the NS&I spokeman knows the difference between the front end and back end of a Banking system.
Probably stuck his head in the Computer room "Everything alright lads ? good......"
15-07-2024 7:56 PM - edited 15-07-2024 8:07 PM
This thread has seemed to be in an infinite loop
Like others here I can not use my plus net connection.
It is NOT a DNS issue, every DNS server I have checked always resolves secure.nsandi.com to 157.203.60.156
157.203.60.156 does not respond to ICMP/ping so trace route and mtr (my trace route) will not complete.
I performed some basic check the other day and found this
Using my Vodafone hotspot I note when clicking on Login from https:/nsandi.com it redirects you to
https://secure.nsandi.com/thc/policyenforcer/pages/loginB2C.jsf?
But if I use https://secure.nsandi.com the browser reports "secure.nsandi.com redirected you too many times."
So something has changed and maybe now https://secure.nsandi.com is an invalid link.
So use 'Login' from the main site https://www.nsandi.com NOT https://secure.nsandi.com
EDIT: corrected link
15-07-2024 8:01 PM
@Dan_the_Van What you say makes perfect sense - I discovered and reported that route a while back on here. Maybe NS&I should be advising customers they have broken/invalidated that direct link?
15-07-2024 8:02 PM
Nice one @Dan_the_Van The login link on your post is incorrect it tries to load a Zeus.2020 trojan virus
15-07-2024 8:04 PM - edited 15-07-2024 8:14 PM
Sorry I suffer from word blindness so stuff looks correct to me but sometimes not.
Hopefully corrected
@Champnet can you please confirm the link is now good?
15-07-2024 8:17 PM - edited 15-07-2024 8:22 PM
The link on the main page for logging in goes to https://www.nsandi.com/Login which certainly works for me.
This then takes you to a lower level page within the "secure" hierarchy to enter your credentials.
( https://secure.nsandi.com/thc/policyenforcer/pages/loginB2C with some detailed parameters )
My simplistic assumption is that the address used at the very start of this thread was never intended to be saved as a login link and due to changes no longer works at all.
15-07-2024 8:20 PM
The link on the main page is the one that I have been trying all today and it just times out without showing anything.
15-07-2024 8:25 PM
I have used the Login link from the main NS & I page from the very start and the issue is still there. I have never tried to just use secure.nsandi.com etc etc directly in the browser.
15-07-2024 8:27 PM
@Dan_the_Van Corrected, now good, have you noticed the log in link on the menu page tries to load https://www.nsandi.com/login ?
15-07-2024 8:38 PM - edited 15-07-2024 8:39 PM
I have noticed the /Login link but it seems to redirect to the long link I posted previously
There seems to an issue with some Plusnet subnets not connecting. Other Service Providers networks it may just be the secure.nsandi.com link doesn't work
15-07-2024 8:53 PM
I'm having the same issue on 15 July 2024.
When I spoke to NS&I they are telling customers that it is specifically Plusnet that is causing the problem. If Plusnet disagree they need to contact NS&I!!
I have managed to login via EE 4G network - so it's not a problem on the EE network (i.e. not affecting all BT-owned networks).
This is very frustrating!!
15-07-2024 8:54 PM
Then it's PN and Zen...
- Everything else
