Can't reach NS&I login page
- Everything else
- Re: Can't reach NS&I login page
Wednesday
Thanks Rob
That is probably good advice
Bless you!
Wednesday
Correct
I can reach the NS&I home page (https://www.nsandi.com) and read all about their products and services, but as soon as I click the Login button, which is supposed to take you to https://secure.nsandi.com, the connection is interrupted and I get the message that the site has taken too long to respond, and I should contact my ISP.
Wednesday
Strange, @Clarissa - I can get the login page if I go via the homepage.
Wednesday
I also have this exact issue. I did speak to support but didn't really have any luck. Hopefully, the Plusnet guys will see that this is not isolated and get it sorted.
Wednesday
I do hope so
Wednesday
Thread moved from My Router to Everything Else.
Also a redirect from https://community.plus.net/t5/Full-Fibre/Login-for-nsandi-com-won-t-respond/m-p/1977076 which I have locked in favour of this thread.
Forum Moderator and Customer
Wednesday
Same issue here using any of the suggestions above.
No issue reaching the Log In page if using a VPN.
Wednesday
As others have reported
I can log in via PN only if I have a VPN connection active (laptop or iphone); I can also log in on my iphone using the mobile connection.
Thursday
I had a fixed IP address on my account and that seemed to be causing the problem. I don't need it so removed it from the account and that's sorted it.
Alternatively use a VPN, Matthew suggested using the Opera browser with built in VPN which worked too as a workaround before we got rid of the fixed IP.
Thursday
Hard to believe all these denied users have fixed IPs.......
Thursday
Well I certainly can't reach it from a dynamic IP!
My home connection is a static but I'm on holiday and by chance the apartment has a Plusnet connection , dynamic in the 87.115... subnet
Thursday - last edited Thursday
I have a static IP address 80.229.xxx.xxx and I cannot login into my NS&I account , fortunately the NS&I app works so I was able to check I am not a winner this month.
I see a syn_sent when attempting to login "TCP 192.168.10.100:53142 157.203.60.156:443 SYN_SENT"
Edit: corrected IP Address
Thursday
and to confirm what @jab1 reported earlier, it doesnt work from a Zen connection either.
Tried VPN to the Office which is on a block of Zen static IPs.
Looks like its affecting most (if not all) of the BT network ?
Thursday
To add a MTR reveals
1. AS??? 192.168.10.1 0.0% 10 1.0 1.1 0.9 1.5 0.2
2. AS6871 254.core.plus.net 0.0% 10 7.5 7.6 7.2 8.3 0.3
3. AS6871 84.93.253.115 0.0% 10 8.2 8.3 7.9 8.6 0.2
4. AS2856 195.99.125.134 0.0% 10 7.8 8.1 7.7 8.6 0.2
5. AS2856 core6-hu0-7-0-26.faraday.ukcore.bt.net 0.0% 10 8.1 8.1 7.6 8.3 0.2
6. AS2856 core2-hu0-15-0-4.colindale.ukcore.bt.net 0.0% 10 9.0 8.9 8.4 9.3 0.2
7. AS2856 acc3-hu0-9-1-0.colindale.ukcore.bt.net 0.0% 10 9.2 9.3 9.0 9.8 0.3
8. AS2856 217.38.123.105 0.0% 10 11.4 11.8 11.1 13.8 0.8
9. AS???
100.0 10 0.0 0.0 0.0 0.0 0.0
AS6871 are plusnet IP's; AS2856 are BT IP's
Thursday
@MisterW wrote:
"and to confirm what @jab1 reported earlier, it doesnt work from a Zen connection either.
Looks like its affecting most (if not all) of the BT network ?"
I'm confused:
It appears to me that for all Plusnet users, https://secure.nsadndi.com does not work, but some of us, myself included, can log in via NS&I's home page? However, for some, eg @Clarissa, that does not work either?
What might cause that difference between PN customers?
Do Zen have some sort of connection with the BT network?
- Everything else
