Can't reach NS&I login page
- Everything else
- Re: Can't reach NS&I login page
10-07-2024 10:41 AM
Yesterday I tried to login to my NS&I account but the link to https://secure.nsandi.com can't be reached and the windows diagnostic tool on my computer said I should contact my ISP
I have rebooted my router and added the site as an exception in my Bitdefender dashboard. Still no luck.
I can reach the page on my phone, but only if I switch from Wi-Fi to 4G, which does suggest it is something on the PN side.
Is anyone else having trouble with this?
PN: Can you sort this out please?
10-07-2024 10:52 AM
10-07-2024 10:52 AM
@Clarissa I don't think it is 'on PN's side' - I can't reach it on a Zen connection either, and they use totally different DNS servers (their own).
10-07-2024 10:53 AM
Thanks for checking
10-07-2024 10:54 AM
OK that's interesting. Thanks for checking.
10-07-2024 11:12 AM
Try the NS&I home page, then click on "Log In" in the top right corner:
10-07-2024 11:22 AM
I did. It doesn't work anymore over normal use of the internet.
I used to be able to access the login page. I have been accessing this site for years, and always using PN internet. But it doesn't work today, or yesterday.
I have found I can get in via a VPN, as well as 4G.
Not sure what to do. The diagnostic tool said my computer is configured correctly, so reluctant to make changes to router or firewall settings my side.
10-07-2024 11:23 AM
Just a thought - wonder if NSI&I have changed the IP for that page and it hasn't worked its way to the DNS servers yet?
10-07-2024 11:24 AM - edited 10-07-2024 11:25 AM
I doubt it's a DNS issue as nslookup resolves https://secure.nsandi.com to 157.203.60.156 on my plusnet connect and mobile data
The site does not respond to ping, you can login using mobile data.
10-07-2024 11:24 AM
Any idea how long it would take?
10-07-2024 11:26 AM
What does "the site does not respond to a ping" mean?
10-07-2024 11:28 AM - edited 10-07-2024 11:37 AM
@Dan_the_Van Strange - I can get the login page up if I go via the home page, but get this response (on FF), if I click the 'secure.nsiandi.com' link in the OP.
Edit to add the response from the OP link:
10-07-2024 11:30 AM
10-07-2024 11:31 AM - edited 10-07-2024 11:32 AM
Same result here.
Possibly not what you want to hear, but if you can get access via a VPN and others are experiencing the same problem, just do nothing, sit back and relax, and wait for things to sort themselves out.
At least NS&I won't have gone bankrupt!
edit: typo
10-07-2024 11:38 AM
To clarify, are you not able to log in via the link on NS&I's home page?
That works for me, on Plusnet broadband, but https://secure.nsandi.com does not.
- Everything else
