Can't login to my account
Noor-Isolde
I know my username is right and my password is right but it says it doesn't recognise one or the other and I can't get the email to reset the password asI can't long on. Any help will be appreciated.
6 REPLIES 6
Legend
Fixes: 255
Re: Can't login to my account
You had this problem in June - what was the resolution then?
MichaelRuble
You can always recover your password using mail if you receive a confirmation letter.
Legend
Fixes: 255
@MichaelRuble I think you are misinformed - at least so far as Plusnet are concerned. So far as I am aware, password recovery is e-mail based, unless one of the Help Team pick it up on here when all else fails.
MichaelRuble
Just passwords are often forgotten and through email address there is an opportunity to renew. But I could be wrong
Legend
Fixes: 255
That's what I said - The password recovery route is via email as standard.
As to 'passwords are often forgotten' - they shouldn't be! Even if you  have a password manager on your device, you should always keep a written record - I actually use an address book.
Fixes: 1,601
I've checked your account and I can't see any reason why you'd be unable to login via the member centre. Are you able to try logging on using a different web browser and device letting us know how it goes?
