Can't login (domain and web space on Force9)
BS6600
I have a domain registered with PlusNet, web pages and email all working OK. but I can't get into my account.
I put username and password and it acknowledges me with my first name but says I can't do anything because there's already a change in progress.
Not having broadband or mobile from PlusNet means their help is unhelpful.
Who can I contact or what can I do - help please.
18 REPLIES 18
willcutforth
Fixes: 113
Re: Can't login (domain and web space on Force9)
Hey there @BS6600 there seems to be an issue with this at the minute. I am waiting for an update and once I have one I will let you know.
 Will Cutforth
BS6600
Now can't sign in at all☹️
James30
Fixes: 32
@BS6600 - Hi can you let me know the website your logging into just to confirm? Thanks
James - Plusnet Sheffield
BS6600
domain bscomputers.co.uk
username bssecure
This is a Force9 account from nigh on 30 years ago.
BS6600
James30
Fixes: 32
@BS6600 - I've raised a task to see if they can fix it @ https://www.plus.net/wizard/?p=view_question&id=235169919.
BS6600
I'd love to watch that question, if only I could login 😉
Fixes: 334
@BS6600 - you appear from that screenshot to be logged into your account - the only thing that notice should prevent is you making changes to your package/service, it should not stop you doing  anything else, like checking tickets, &c.
MatthewWheeler
Fixes: 503
Unfortunately, it still looks like this is ongoing and may not be an easy fix.
We've raised a task to another team to see what can be done
After the 3rd of November I will have a limited presence here as I have moved to a new role
 Matthew Wheeler
BS6600
I may have to request an escalation of this problem.
As of yesterday (15/8/23) I can not send emails to any Gmail address.
The Community says I may have to go into my account to fix this. That looks vvcomplicated so I hope there will be a more universal restoration of normality.
But if not then I need to get into my account
James30
Fixes: 32
@BS6600 - We've been advised of issues with our email but I'm not sure if they are causing you these specific issues. Can you PM me the username you are logging in with on the portal and the domain name. Also let me know if you can send emails to any other email address other than Gmail?
BS6600
My account/user name is bssecure (a Force9 account from 20+years ago)
My email address is bspence@bscomputers.co.uk (a domain registreed with you)
I can email other than @gmail.com. Can't email several gmail.com addresses.
Last successful send was on 14/8/23
Sample response is as follows
      This is an automatically generated Delivery Status Notification.
Delivery to the following recipients failed permanently:
   * billspence42@gmail.com
Reason: A message that you sent to the following recipient could not be delivered due to a permanent error. ** The remote server ?? responded with: ** billspence42@gmail.com ??:?? This message was created automatically by mail delivery software on the server .
Reporting-MTA: dns; avasout-ptp-001 [84.93.230.227]
Received-From-MTA: dns; [192.168.1.16] [90.246.13.211]
Arrival-Date: Thu, 17 Aug 2023 10:17:41 +0100
Final-recipient: rfc822; billspence42@gmail.com
Diagnostic-Code: smtp; 550-5.7.26 This mail is unauthenticated, which poses a security risk to the
Last-attempt-Date: Thu, 17 Aug 2023 10:17:44 +0100
BS6600
Further to the above
First failure was on 15/9/23 at 17:59
I have had sporadic fails all from scripted forwarding of a forum's posts, most of which go OK.  This was not urgent enought to warrant investigation. From memory it was posts from a particular member.
willcutforth
Fixes: 113
Has it been any better in the past 2 days? If not, I am going to raise it to the netops team to see what they can do with it.
 Will Cutforth
