Can't get phpinfo to work on my ccgi server
aeneareid
I wanted to check the php settings on the ccgi server. So, I wrote a little php program containing the code:
<? phpinfo();?>
but it displays nothing. Also tried
<? echo phpinfo(); ?>
but that didn't work either.
What am I doing wrong?
3 REPLIES 3
spraxyt
Aspiring Legend
Fixes: 75
Re: Can't get phpinfo to work on my ccgi server
You are not doing anything wrong. Hostopia have blocked a number of infrastructure commands to improve security and unfortunately phpinfo() is one of them Sad .
David
aeneareid
Ah! I rather feared that might be the case.
Do you know if ftp is enabled from within php?
spraxyt
Aspiring Legend
Fixes: 75
PHP lists the ftp extension as present but I don't know whether it works. Worth giving it a try though. Smiley
David
