Can't connect to websites via FTP
- Everything else
- Can't connect to websites via FTP
26-03-2020 11:25 AM
Message 1 of 2
(172 Views)
1 REPLY 1
Re: Can't connect to websites via FTP
03-04-2020 12:15 PM
Hi @aka_sb,
I'm sorry for any inconvenience that this issue is causing you and for the delay in getting back to you on here. I've checked your line but have been unable to determine the cause of this problem. It could potentially be the case that the IP address that you're connected on is causing an FTP issue. I've done a session kill on your line to try and resolve this - please turn your router off at the power for at least 15 seconds and then back on. Once the router is back on, it should have moved you to a different IP address.
Message 2 of 2
(112 Views)
- Everything else
