Can't connect to local MySQL server errors
- Everything else
- Re: Can't connect to local MySQL server errors
14-10-2007 2:02 AM
I am trying to set up a script that will be called via Crontab to backup the mysql database tables on the rumpus server.
I keep getting these errors:
36 tables were optimized
/usr/bin/mysqldump: Got error: 2002: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) when trying to connect
The mysql dump command is:
/usr/bin/mysqldump --skip-extended-insert --user martek --password=**************** martek_f9 | gzip
I think it may be a problem with paths but I am not sure.
I am using the mysqldump.php script version 0.6, By Richard Williamson (aka OldGuy).
the config variables are set to (password hidden):
$cfg[0]['dbhost'] = 'rumpus'; // your mySQL server name
$cfg[0]['dbuser'] = 'martek'; // your mySQL user name
$cfg[0]['dbpass'] = '****************'; // your mySQL password
$cfg[0]['dbname'] = 'martek_f9';
Can someone please advise me where I am going wrong.
Message 1 of 5
(1,724 Views)
4 REPLIES 4
14-10-2007 9:59 AM
Just to confirm, are you running this on the PN CCGI server or your own *nix server?
If your own you need to use rumpus.plus.net
Message 2 of 5
(449 Views)
14-10-2007 4:29 PM
The MySQL dump command quoted, neglects the MySQL server hostname. When this happens, it falls back to the unix socket approach, but fails as this is not used.
Are there any other settings to complete?
Got a link to the script involved, and I will see if I can see any cause.
Message 3 of 5
(449 Views)
14-10-2007 9:30 PM
Quote from: Peter Just to confirm, are you running this on the PN CCGI server or your own *nix server?
Thanks for the reply Peter. I am running it from a php script on PN CCGI "crofters".
Message 4 of 5
(449 Views)
14-10-2007 11:29 PM
As Phil suggests, it needs to have --host=rumpus in the mysqldump command line options
Message 5 of 5
(449 Views)
- Everything else
