Can't FTP to GoDaddy
- Everything else
- Can't FTP to GoDaddy
12-03-2016 5:31 PM
Can't connect to FTP to GoDaddy i was told by Plusnet "it is likely that it is some sort of encryption that is blocking it "
I have tried using laptop and reinstall pc but same issue.
Message 1 of 3
(790 Views)
2 REPLIES 2
Re: Can't FTP to GoDaddy
12-03-2016 7:12 PM
Which FTP client are you using? Is it set to use Active or Passive mode?
Is the broadband firewall turned on?
David
Message 2 of 3
(273 Views)
26-03-2016 1:35 PM
Sorry for late reply.
Using FileZilla and have tried others.
I have tried it with all Firewalls off broadband and PC and also tried setting myself as DMZ.
Message 3 of 3
(273 Views)
