Can I get PHP?
7up
Fixes: 17
Can I get PHP?
We've been with PN for years and I've never bothered using the hosting because it's a static site. Others around here seem to have php/mysql on their sites which is cool but i'm clearly left out in the cold! I seem to remember this was something to do with the legacy product we signed up for years ago which has now changed to the more modern packages.
Now I can live with that as I do have alternative hosting however PN hosting would be very useful to me if it had PHP/mysql. Is there any way to get this enabled or am I stuck with static?
11 REPLIES 11
kmilburn
Re: Can I get PHP?
As you've come from a legacy product and have a website, you should be able to have PHP, but you need to enable CGI support.
In the portal, on the Website Settings page, you'll hopefully have a CGI link,  if so, follow it and activate CGI.
spraxyt
Resting Legend
Fixes: 75
Re: Can I get PHP?
If CGI and MySQL don't appear as icons on your Member Centre Website settings menu it would seem the answer is 'no'. Only product components available and in use on legacy products were retained when upgrading to current products which don't provide webspace. Not all legacy products included CGI.
David
Oldjim
Resting Legend
Fixes: 63
Re: Can I get PHP?
They appear on mine and I have never used them
Strat
Fixes: 565
Re: Can I get PHP?
And on mine, I had a very brief play with them.
7up
Fixes: 17
Re: Can I get PHP?
Bsf luck for me i guess.. this is my website settings page in the portal:
MauriceC
Resting Legend
Fixes: 17
Re: Can I get PHP?
Just checked my account and I only have webspace and webstats - No CGI.  I used to have it some years back but never really used it because of the back-levels on PHP and MySQL.
I guess I'll not be able to take advantage of the new service now Cry
Maurice
TORPC
Re: Can I get PHP?
Ive not set a website with PN so No Icons lol
However I did access https://mysql.plus.net/
From
http://portal.plus.net/tools/mytools_index.html?membermenu=tools
Hope this helps
Edit:
The version that links to is outdated and going to be turned off, as I found out when I posted (Plusnets phpMyAdmin several versions out of date)
7up
Fixes: 17
Re: Can I get PHP?
Well no reply from PN so I'm going to assume this is a no!
Thanks for your help peeps
bobpullen
Fixes: 316
Re: Can I get PHP?
If the icons aren't present in the Member Centre then your account type doesn't offer access to the service unfortunately.
7up
Fixes: 17
Re: Can I get PHP?
Yeah I figured that Bob but what i was asking is .. is there a way to upgrade the hosting?
spraxyt
Resting Legend
Fixes: 75
Re: Can I get PHP?
None of the current residential accounts offer hosting at all. Current business accounts offer basic (HTML) hosting but not cgi which is needed for PHP. You would probably be directed towards Pay As You Host for hosting within the Plusnet stable, but third party hosting is likely to be better value.
David
