Can I get PHP?
- Everything else
- Can I get PHP?
Can I get PHP?
04-01-2014 11:53 AM
Now I can live with that as I do have alternative hosting however PN hosting would be very useful to me if it had PHP/mysql. Is there any way to get this enabled or am I stuck with static?
Re: Can I get PHP?
04-01-2014 1:38 PM
In the portal, on the Website Settings page, you'll hopefully have a CGI link, if so, follow it and activate CGI.
Re: Can I get PHP?
04-01-2014 1:44 PM
Re: Can I get PHP?
04-01-2014 2:34 PM
Re: Can I get PHP?
04-01-2014 2:36 PM
Re: Can I get PHP?
04-01-2014 2:37 PM
Re: Can I get PHP?
05-01-2014 4:00 PM
I guess I'll not be able to take advantage of the new service now
Maurice
Re: Can I get PHP?
06-01-2014 11:52 AM
However I did access https://mysql.plus.net/
From
http://portal.plus.net/tools/mytools_index.html?membermenu=tools
Hope this helps
Edit:
The version that links to is outdated and going to be turned off, as I found out when I posted (Plusnets phpMyAdmin several versions out of date)
Re: Can I get PHP?
06-01-2014 3:03 PM
Thanks for your help peeps
Re: Can I get PHP?
10-01-2014 11:13 AM
Re: Can I get PHP?
10-01-2014 11:43 PM
Re: Can I get PHP?
11-01-2014 1:08 AM
