CGI space and file permissions
- Everything else
- CGI space and file permissions
11-02-2011 11:49 PM
I have a form in my CGI space that uses a couple of .php files and half a dozen .htm files in the root, and a couple of images in a folder.
I have set all the permissions to 750. Is this correct?
TIA.
TIA.
Message 1 of 5
(1,695 Views)
4 REPLIES 4
Re: CGI space and file permissions
12-02-2011 12:03 AM
Hey Tia,
You may find this link useful: http://community.plus.net/library/settings/cgi-platform-php-upgrade-faq/
It's the FAQ for when the CGI/PHP platform was upgraded.
Regards,
Matt
Regards,
Matt
Message 2 of 5
(177 Views)
12-02-2011 1:25 AM
HTML and image files should have permissions 0640, PHP files should be 0700, folders should generally be 0710, but the folder containing images needs to be 0750 so that the server can locate the images.
David
Message 3 of 5
(177 Views)
25-02-2011 7:32 PM
Oops, SOLVED!!!
solved by: http://community.plus.net/forum/index.php/topic,84349.0.html
I know this may seem like a silly question, but how can I set the attributes for all files of a given type in a folder tree e.g. setting all php files to executable?
I've tried to use chmod via a script and I can set all in one folder but whatever I try it just won't recurse.
odd, as I bet rm -r would happily delete everything
Message 4 of 5
(177 Views)
25-02-2011 11:54 PM
Running chmod recursively should also happily change *everything*, directories and files that match any pattern you specify, but that is probably not what you want.
Doesn't Gabe's script (in the post you linked to) do what you specified? You can adapt that to process different file types if needed.
David
Message 5 of 5
(177 Views)
- Everything else
