CGI issue
- Everything else
- Re: CGI issue
CGI issue
05-09-2013 6:20 PM
I've just loaded up a new phpBB folder set up to my CGI space.
http://ccgi.crazeeworld.plus.com/cats/install/index.php
The page is there if I go through FTP, but in Firefox, I get
"Server error!
The server encountered an internal error and was unable to complete your request.
Error message:
Premature end of script headers: index.php
If you think this is a server error, please contact the webmaster.
Error 500
Thu Sep 5 18:18:56 2013
Apache"
Any ideas, guys?
"Server error!
Error message:
Error 500
Apache"
Any ideas, guys?
Message 1 of 4
(1,448 Views)
3 REPLIES 3
Re: CGI issue
06-09-2013 1:28 AM
The CGI Platform PHP Upgrade FAQ provides some guidance on likely causes of that error.
In particular, are there any .htaccess files with disallowed options in the path? Have you set file permissions correctly? Were text file transfers done as ASCII so the files have the correct line endings?
David
Message 2 of 4
(444 Views)
Re: CGI issue
06-09-2013 3:07 PM
Will look into that and re-up.
Message 3 of 4
(444 Views)
Re: CGI issue
20-10-2013 11:20 PM
Its prob going to be permissions or plusnet possibly not supporting the platform you're uploading
install filezilla and check permissions
you should not need to upload again!
Message 4 of 4
(444 Views)
