CGI Space changes ...
- Everything else
- Re: CGI Space changes ...
20-03-2014 2:11 PM
my plusnet domain is sunwheel.force9.co.uk.
I have a domain, jacksrake.co.uk, hosted by 1and 1 which is currently pointed to: ccgi.sunwheel.f9.co.uk
I have, since the migration [I think!] made changes (mostly changes to pictures) to the website which appeared to show up properly but now it appears to have reverted to the old version.
Could some kind soul please tell me exactly what I need to change at 1and1?
"Do this as follows:
www CNAME <your_domain>.
<your_domain> A 91.136.8.9" Makes no sense to me. Sorry if I'm a bit thick!
20-03-2014 3:09 PM
The images displayed on the site and all the links appear to reference ccgi.sunwheel.force9.co.uk and clicking on the Home menu item probably displays the page from that server.
Is the problem that what shows initially is the page on the 1&1 server?
David
Edit: Looking at the page source shows a Frameset redirect is being used. I would expect this to continue working with the new server.
20-03-2014 9:50 PM
My previous post was made at work where I first noticed the website seemed to have reverted to the previous version.
I'm now at home and have checked the uploaded files and the they are indeed the files of the previous vesion. I have started to re-upload the new version and all seems well so, clearly nothing needed changing at my domain host.
I'm still at a loss to explain why the new files have disappeared to be replaced by the old ones. I uploaded the update, via the new control panel, around three weeks ago, after receiving my migration confirmation email. Everything worked at the time and I only noticed today that the old version of the website was loading ... even though I had deleted the old files. Is it possible plusnet have restored some sort of backup?
jim:quote
20-03-2014 11:09 PM
Quote from: sunwheel I'm still at a loss to explain why the new files have disappeared to be replaced by the old ones. I uploaded the update, via the new control panel, around three weeks ago, after receiving my migration confirmation email. … Is it possible plusnet have restored some sort of backup?
Three weeks ago could be the key here.
Over the weekend 28/02-03/03/2014 Hostopia mounted week old versions of our file systems. This was corrected on the Monday afternoon but as a consequence any changes made over that weekend were lost. Unfortunately if your changes were made that weekend you will have been affected.
21-03-2014 9:08 AM
21-03-2014 9:15 AM
Aha! It all makes sense now; it will have been that weekend.
No worries, I have uploaded all the new stuff again and all is fine now.
Thanks, as usual, for the speedy and useful input.
Cheers!
Mark.
22-03-2014 10:01 PM
It requires two lines, $basedir/ and $baseurl to be edited. Under the old setup, I had this configured as follows:
$basedir = "/files/home1/username/cgi-bin/foldername/counter";
$baseurl = "http://ccgi.username.plus.com/cgi-bin/foldername/counter";
I've tried all sorts of variations, including the path on hostedc50.megawebservers.eu to /services/webpages/c/c/ccgi.username.plus.com, but nothing makes the counter work. I would have thought that it's only the former of these two lines that needs changing. But to what?
This file is referenced by an HTML file in my homepages webspace, via lines such as
<img src="http://ccgi.username.plus.com/cgi-bin/foldername/counter/gcounter.pl?countername&d&0&5">
22-03-2014 11:49 PM
The key change is to find the /.htaccess in your root directory and disable it by renaming it (eg add something before the leading '.') or deleting it. This will stop web/url references to /cgi-bin being redirected to /public/CGI-BIN with the real /cgi-bin being ignored.
Then move any cgi scripts (and associated data/image files) to (folders) within /cgi-bin with .pl and .cgi scripts executable (chmod 700).
To ensure /public/CGI-BIN can't be used I suggest renaming it (or deleting it if empty), along with a possible /public/cgi-bin soft link to /public/CGI-BIN if there is one.
The full path to files in the real /cgi-bin will then be /services/webpages/c/c/ccgi.username.plus.com/cgi-bin/... (whatever)*
and their urls http://ccgi.username.plus.com/cgi-bin/... (whatever)
I think these are what you expect, and they should work once the crucial step of removing /.htaccess is done.
* You might sometimes see /util/ included in the path as in /services/webpages/util/c/c/ (etc). Strictly /util/ shoud be included, but it works without it too.
David
23-03-2014 1:15 AM
I'd had a good look through all of this thread, one or two others, the help page linked in my email and various bits of the PDF docs relating to the new service (the kind of insightful documentation that suggests things like: 'Change Password: Clicking this button provides a function to change your password'), etc., but hadn't seen anywhere that mentioned the 'real' cgi-bin had to be activated by disabling the 'fake' one.
A few other questions whilst I'm here:
I renamed the .htaccess file, but trying to delete it or another directory in my /public folder doesn't work. My FireFTP client merely indicates
'Error message= NS_ERROR_NOT_AVAILABLE:
URL= chrome://fireftp/content/js/remote/remoteTree.js
Line Number= 489'
Is there a complication with deleting CGI files via FTP or is this an issue with my client?
Somebody earlier in this thread mentioned they'd been able to create an extra FTP user in addition to the master, who had permissions to all directories. How? When I tried to do that it would only let me pick one subfolder, and leaving the field blank or adding a / resulted in a 'directory not valid' error. (That Master FTP password really should be at the top of that page with additional restricted users underneath, but there's no point venting my spleen about that here).
The other default subdirectories of 'private' and 'secure' - do they have any particular function / recommended use or are they just there as generic template folders to give users ideas?
23-03-2014 4:28 PM
FTP Manager lets me create an additional Directory FTP user with access to /, which should mean all directories (I haven't tried using it). To do this I click the Create button to display additional form fields. Fill in name and password twice on the left, don't click any directories in the list on the right, just type / in the textbox. Finally click the Create button and it does.
This also works with a test account I have access to, though from memory I previously got the "directory not valid" error you mention with that test account. Did you have anything selected/highlighted in the directory list when you tried with just / in the textbox?
The /private directory is used by the system to hold phpMyAdmin configuration files when you "install" (ie initialise/configure) it using the Control Panel tool. There will also be a /public/phpmyadmin link - your choice of name - (in /public of course) which points to the system phpmyadmin directory. Files in /private are not accessible from the Internet (the web root is /public).
I think /secure might be a placeholder for HTTPS access (which we don't have). On my test account /secure is a link to /public and I have a second similarly named directory which is a link to /cgi-bin. I expect the server configuration would use these if we had HTTPS access.
David
23-03-2014 9:26 PM
I've updated the forms from my old 8.22 version to the latest 9.06 version available at tectite.com, which now use PHP5 instead of PHP4. Should be no problem, and I've not made any other configuration changes aside from modifying the paths. I've initially picked a form that doesn't rely on any image captchas just to avoid one further stumbling block straight away. The old PHP scripts had been moved automatically into /public/CGI-BIN/path/to/old_scripts.php, but I tried to put my new one in /public/path/to/script.php. Obviously I also updated my HTML form with the new path, but upon submission I get an error:
Not Found
The requested URL /public/path/to/script.php was not found on this server.
In case this was PHP5 related or an issue with the new script, I tried redirecting the HTML form to the old one in /public/CGI-BIN/path/to/script.php. I get the same error. What's going on?
Regarding the other points, I still could not get the additional restricted user to have access to /, so I just deleted the account. And I can delete files from the File Manager in Control Panel that can't be deleted in my client, FireFTP. No idea why, it can delete fine from my www webspace.
23-03-2014 10:14 PM
I've just downloaded formmail.zip from www.tectite.com to take a look at it but got version 8.36. How did you get version 9.06?
David
23-03-2014 10:52 PM
As for the script version, I noticed it said the latest version is 8.36 on the FormMail homepage, but when I went to upload and convert an existing one, it offered me either 8.36 or 9.06, with the latter already highlighted by default. There was some reference to the new version being beta but that was seemingly the 9.0 version, not 9.06. I don't know why the new one isn't made more visible unless it's either not fully stable or because they regard dropping PHP4 support as too problematic for the time being.
Edit: pasted appended phrase at semi-nonsensical place.
24-03-2014 8:09 PM
However depending on their extension included files might be. If their extension is .php their contents should be safe, but if .inc or .ini (say) they might be viewable. It might require guesswork but someone might guess correctly. For example having sensitive information in a file called formmail.ini would probably be pushing your luck. If it was called dlmxxpkvrf.ini it is less likely to be discovered, but that possibility still exists.
You could move included files to subdirectories (preferably not called ./includes) and/or use .htaccess directives to deny direct browser access to all *.ini files, but moving such included files into a folder above the webroot should protect them. Which method to choose depends perhaps on your sense of paranoia.
David
27-04-2014 11:21 AM
reptonresourcepage.co.uk. a 91.136.8.9
www cname ccgi.geraldholdsworth.free-online.co.uk.
Also, I've tried to log into the Control Panel, with the supplied username and password, and am told that it is an Invalid Username or Password! However, I can log into my FTP space, using Firefox FTP, using these credentials fine.
- Everything else
