CGI Space changes ...
- Everything else
- Re: CGI space changes... improvements/inclusions a...
Re: CGI Space changes ...
21-12-2013 5:27 PM
Quote There is a script that should fix that for you, but at this stage, I'd just wait for the migration.
Gabe
Thanks, Gabe. I've tried your script (3 reasons - wanting to learn, wanting something that works before the move and because my phpBB isn't new, it's moved from elsewhere and I'd like to restore it fully).
I ran the script, it duly created php.ini, symlinks and /tmp (the second of your magic scripts I've used, thanks you) but in my ACP, php information still showed upload_tmp_dir as not set, and I was still unable to upload. Looking in the php.ini, the line for upload_tmp_dir was commented out, so I changed that and pointed to /tmp - and php information then showed it to be set to that, but still no upload.
Noting that /tmp is the default and it may be full (although I'm confused how /tmp in my root can be full?) I also created phpBB3/tmp and pointed to that, but no joy.
Maybe I have the wrong permissions on the tmp folder - or perhaps, the permissions it need to be written to by a board user are incompatible with those enforced by suEXEC?
21-12-2013 7:53 PM
If you run phpinfo() in a .php script this should show the loaded configuration file (a few lines from the top) is yours and upload_tmp_dir (in the PHP Core section) is your own /tmp.
BTW did you remove those ini_set hacks from config.php and index.php?
David
Edit: correct text where I meant to put phpinfo.
21-12-2013 8:11 PM
(For those who were not around a the time, this was a restricted version of full PAYH.)
After a workaround battle with Safe Mode (which upset several PHP-based packages), the need for additional Permissions relaxations (often 644 to 666), Magic Quotes and so on, the websites which my business depended upon worked.
Since CCGI is now finally to be be moved to a white-labeller, PLEASE PLEASE could PN provide some ADVANCE visibility about the future of:
- Preview accounts
- 'home pages' (i.e. non-active) website space
Q's that come to mind:
Will hosting of the DNS associated with the moved websites also be moved (to allow changes to be made via the new hoster's control panel) ?
What about email submitted from e.g. PHP in the new environment? It will presumably have a non-PN IP address so will be subject a more restrictive 'number of addressees' limit
21-12-2013 8:33 PM
21-12-2013 8:59 PM
Quote from: spraxyt When you checked the value of upload_tmp_dir in the php.ini created by Gabe's script did you check the value of the setting around line 562 or at the bottom of the file? The earlier one is the current unset default but the one at the bottom of the file overrides that and should be the full path to the newly created /tmp located in your own webspace.
Thanks David. I was looking at the one at line 562. I had searched for occurrences of tmp; I did find one at the bottom of the file but it was soap.wsdl_cache_dir="/tmp", upload_tmp_dir - that's my ignorance of php, I didn't think soap or wsdl would be used in uploading an avatar. It makes no difference whether I comment it out or not.
Quote If you run a phpini.php script this should show the loaded configuration file (a few lines from the top) is yours and upload_tmp_dir (in the PHP Core section) is your own /tmp.
OK, I didn't know about phpinfo, I do now, thanks, and I see it's what the ACP on phpBB was using to report the setting.
Quote BTW did you remove those ini_set hacks from config.php and index.php?
I didn't
So, with the ini-set hacks removed, and phpinfo confirming where upload_tmp_dir is set to, I still get the error, whether I set to /tmp or /phpBB3/tmp
I have made sure I used ascii for my ftp transfers, the tmp folder permission is set to 710 and I've verified that I can read a file in the folder from my browser.
When trying (as a board user) to upload a file, such as a small jpg as an avatar, or an attachment to a post, I still get the error:
Quote Temporary folder could not be found. Please check your PHP installation.
21-12-2013 10:10 PM
Quote from: Chris3005 I still get the error
Apologies, I should have checked this to begin with, as hominid had flagged it up earlier. I'm also getting the upload error in Wordpress, also in SMF, but not in Dokuwiki or a script of my own. Not immediately clear what's causing the glitch. The database is still talking. I guess the migration team has switched something. Probably missing the obvious. Not an ideal time to debug. Urrgh.
Gabe
21-12-2013 10:34 PM
Chris
22-12-2013 12:34 AM
I created an upload form and test script to check out file uploading and had no problems either using the standard php.ini or with Gabe's 'own-webspace' version.
With the standard php.ini the uploaded file goes temporarily into /tmp
With the own-webspace version it goes into the upload_tmp_dir defined in that php.ini
Upload (using my own form and script) also works on the new server. It uses a designated upload_tmp_dir on there.
David
22-12-2013 10:26 AM
Unfortunately I don't (yet?) have the skills to write some for myself.
Chris
22-12-2013 12:45 PM
#!/bin/bash
echo "Content-type: text/html"
echo
mkdir tmp && chmod 710 tmp
cp /etc/php5/cgi/php.ini ~ && chmod 600 php.ini
if [ -e php.ini ]
then
echo "
; Override section
display_errors = Off
expose_php = Off
register_globals = Off
upload_tmp_dir = $(pwd)/tmp
session.save_path = $(pwd)/tmp
session.use_only_cookies = 1
session.gc_probability = 1" >> php.ini
for file in $(find . -mindepth 1 -type d -print0 | xargs -0)
do
[[ $(ls "$file") =~ \.php ]] && ln -s "$(pwd)/php.ini" "$file/php.ini" && echo "$file/php.ini<br>"
done
fi
Sorry, that's properly bad coding but quick to type. It fixes the upload problems I was seeing, at least. Apologies for rushing - Christmas.
Gabe
22-12-2013 4:15 PM
Uploading an avatar to images/avatars/upload using phpBB3 version 3.0.5 works OK for me (using the default php.ini). The uploaded avatar displays with my posts.
File permissions for those directories are 0710 and that for the uploaded image file is 0600.
I assume this means the Force9 server /tmp is not full.
Avatar uploading and display also works on the new server where I have phpBB3 version 3.0.12.
David
CGI space changes... improvements/inclusions and more q's im sure
22-12-2013 6:05 PM
if there is a dedicated topic for questions etc, i haven't seen it, so im just banging it in here.
it may become more clear about what server modules are available, but i would hope the full suite of XML XSL XSLT modules will be available (ive posted before on this and i got a muted response on updating modules to deliver this)..... so i live in hope.....maybe this can be confirmed at some point, or 'arranged' if needs be 🙂
Merry Christmas everyone and best wishes for the new year
Re: CGI space changes... improvements/inclusions and more q's im sure
22-12-2013 6:25 PM
XSL enabled
libxslt Version 1.1.26
libxslt compiled against libxml Version 2.7.7
EXSLT enabled
libexslt Version 1.1.26
Gabe
22-12-2013 6:38 PM
Questions on the migrated service can go in the stickied post at the top of this forum.
David
22-12-2013 6:42 PM
ps: how did you do the test ? can i start to hack around too yet ?
- Everything else
