CGI Password Reset?
- Everything else
- CGI Password Reset?
CGI Password Reset?
13-07-2009 6:47 PM
Rang plusnet and asked for both the CGI and MySQL, MySQL was reset however no notification that CGI was reset.... Created a ticket today and still nothing as of yet?
Can someone confirm the difficulty behind resetting a pass word please
Re: CGI Password Reset?
13-07-2009 8:38 PM
13-07-2009 11:32 PM
13-07-2009 11:50 PM
Support ticket is 12hrs old and no password reset
14-07-2009 8:35 AM
14-07-2009 8:56 AM
14-07-2009 9:02 AM
adie:quote
14-07-2009 9:08 AM
14-07-2009 9:10 AM
14-07-2009 10:16 AM
Quote from: sophos9 Anyone? Need to build a website...
I'll take a look now for you...
Edit: Now done, I've passed your ticket back to you.
14-07-2009 10:35 AM
Just got text notification if the password reset. Sorry if I seemed a bit frustrated.
Quick question, what's the volume of password resets that you get? Is there an opportunity for plusnet to create a cgi password reset option in the portal? Customers could self serve thus reducing your inbound call/ mail support volumes?
14-07-2009 11:12 AM
At the moment, password resets are done using sudo access by those with the relevant permissions. This is why your ticket took a while to get round to because not all of the front-line support staff can do this.
14-07-2009 3:12 PM
Prompt shows cshell02.plus.net
Can you please reset the password to something other than the portal password and test for me?
Thanks in advance
14-07-2009 6:03 PM
20-07-2009 4:30 PM
Changing the password in CGI led to multiple password being needed for FTP and CGI, seem as if PN had replication issues in the backend. This was raised again as a ticket and despite it being routed through to the right team, all they have done is reset the password which has created two problems
1) The password replication issues seems not to have had anything done on it
2) The password reset has not worked and now NONE of the my password WORK
I just want a password that works, why is this so difficult
