CCGI server availability
- Everything else
- CCGI server availability
03-08-2007 3:01 PM
Just curious !!!!
Why is the CCGI server not available if you are not connected directly to PN? I accept that PN want it to be available only to paying customers but surely they must know when someone tries to log on that they are a paying customer.
...........just a little frustrating because I spend quite a bit of time on a mobile (Vodafone) connection, like now, and I am unable to make alterations to my CCGI until I return home.
Message 1 of 5
(4,137 Views)
4 REPLIES 4
Re: CCGI server availability
03-08-2007 3:58 PM
If someone got old of your login details they would be able to login to your ccgi account and do nasty things and PN would not be able to trace them.
Just because you can login does not mean you were the owner of the account.
For such reasons PN have locked down the ccgi server to only allow PN IP connections to reduce the likelihood of such a situation occurring. Also as it will only be a PN IP they can track who's account was used and allow them to block it until the problem is sorted out.
The ccgi server by it nature is an ideal candidate for hackers to try to break into and use for maliciously activity so this kind of activity can also be tracked and blocked more easily if only PN IPs were allowed access.
Message 2 of 5
(1,353 Views)
03-08-2007 4:27 PM
Fair comment, thanks Peter
Message 3 of 5
(1,353 Views)
03-08-2007 4:30 PM
Quote from: Peter The ccgi server by it nature is an ideal candidate for hackers to try to break into and use for maliciously activity so this kind of activity can also be tracked and blocked more easily if only PN IPs were allowed access.
How true that is
I don't think my case was a fault of Plusnets security but rather on earlier version of phpBB that I was running.
Anyway Im all for good security by Plusnet if it helps prevent nasties getting in.
Message 4 of 5
(1,353 Views)
03-08-2007 5:00 PM
As you'll have seen elsewhere link to my phpBB site was diverted to Turkish site by well known hacker
Message 5 of 5
(1,353 Views)
- Everything else
