CCGI errors
paulcobb
CCGI errors
I am running a script on CCGI server which has been operating for a long time, and just started getting errors:
Warning: session_start(): open(/tmp/sess_9007155a88e0f6cc8375890dab61dab4, O_RDWR) failed: No space left on device (28)
I am thinking this is an issue with the /tmp directory
Would anyone care to comment please?
Paul
11 REPLIES 11
mellis4148
Re: CCGI errors
My only comment is that it is happening to me as well.
Peter_Vaughan
Re: CCGI errors
Looks like one of the network drives on the CCGI server has run out of space. You both need to raise a ticket and include the error message.
paulcobb
Re: CCGI errors
I've raised a ticket [23530785]
Still happening this morning!
Paul
Merrick
SQL Database size
Is there a limit on the size of the database you can have in SQL?
I have used 150MB of my cgi webspace and have started getting errors using my eve-o killboard that refer to not being able to save the datbase.
Warning: session_start(): open(/tmp/sess_dca982cbe3df60d1b0950a9848b82c23, O_RDWR) failed: No space left on device (28) in /share/storage/02/sc/"username"/shado/common/class.session.php on line 26
Thanks for any help
Merrick
chillypenguin
Re: SQL Database size
Moderators Note
Threads about no space left for temporary sessions merged.
Jonathan
Also two posts by Jelv removed as they just pointed to the other thread.
jelv
Fixes: 10
Quote from: chillypenguin
Moderators Note
Fine except you've also removed my hint that the second poster should raise a ticket!  Undecided
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Merrick
Re: CCGI errors
ah cool, well at least someones on it Smiley
jelv
Fixes: 10
Re: CCGI errors
It appears at present nobody from Plusnet is on to it. Sad That's why you need to raise a ticket.
paulcobb
Re: CCGI errors
The responses from CS were:
1.  I will forward this to our network engineers.
(INTERNAL)
please advise, appears to be a server problem
2. The following comment was added to the Question
(INTERNAL)
monitoring systems suggest diskspace is ok..
This may be the case - but what is causing the problems then ?Huh
The common 'No space left on device (28)'  must point to something.
Paul
paulcobb
Re: CCGI errors
Reply received from CS 4th December 2007
'I have found the cause of the problem, our monitoring did pick it up, however it was deemed to be a transient problem and so was not raised to our engineers. The root cause was that the /tmp volume (which is on the shared storage) ran out of inodes a number of times from friday onwards.
I have increased the number of inodes available on the volume by 25%, we will continue to monitor this and will increase it again if necessary.'
Paul
Merrick
Re: CCGI errors
ah a solution! excellent. my problems stopped a little while ago but still wondered why ti was happening.
