CCGI errors
- Everything else
- Re: CCGI errors
CCGI errors
30-11-2007 7:21 PM
Warning: session_start(): open(/tmp/sess_9007155a88e0f6cc8375890dab61dab4, O_RDWR) failed: No space left on device (28)
I am thinking this is an issue with the /tmp directory
Would anyone care to comment please?
Paul
Re: CCGI errors
30-11-2007 7:48 PM
Re: CCGI errors
01-12-2007 7:48 AM
Re: CCGI errors
01-12-2007 10:01 AM
Still happening this morning!
Paul
SQL Database size
01-12-2007 4:26 PM
I have used 150MB of my cgi webspace and have started getting errors using my eve-o killboard that refer to not being able to save the datbase.
Warning: session_start(): open(/tmp/sess_dca982cbe3df60d1b0950a9848b82c23, O_RDWR) failed: No space left on device (28) in /share/storage/02/sc/"username"/shado/common/class.session.php on line 26
Thanks for any help
Merrick
Re: SQL Database size
01-12-2007 5:11 PM
Threads about no space left for temporary sessions merged.
Jonathan
Also two posts by Jelv removed as they just pointed to the other thread.
01-12-2007 5:20 PM
Quote from: chillypenguin Moderators Note
Fine except you've also removed my hint that the second poster should raise a ticket!
Re: CCGI errors
01-12-2007 5:21 PM
Re: CCGI errors
01-12-2007 5:26 PM
Re: CCGI errors
01-12-2007 7:42 PM
1. I will forward this to our network engineers.
(INTERNAL)
please advise, appears to be a server problem
2. The following comment was added to the Question
(INTERNAL)
monitoring systems suggest diskspace is ok..
This may be the case - but what is causing the problems then ?
The common 'No space left on device (28)' must point to something.
Paul
Re: CCGI errors
05-12-2007 9:34 AM
'I have found the cause of the problem, our monitoring did pick it up, however it was deemed to be a transient problem and so was not raised to our engineers. The root cause was that the /tmp volume (which is on the shared storage) ran out of inodes a number of times from friday onwards.
I have increased the number of inodes available on the volume by 25%, we will continue to monitor this and will increase it again if necessary.'
Paul
Re: CCGI errors
05-12-2007 10:33 AM
