CCGI Webspace DataTables Warning
spark43
I've found another problem with my Webtrees program.
When I click on User Administration I get the following error message:
DataTables warning: table id=DataTables_Table_0 - Invalid JSON response.
Using Firefox network debugger the response is:
The requested URL was rejected. If you think this is an error, please contact the webmaster.
Your support ID is: 10457433133417308270.
I've discussed it with the Webtrees support and he thinks it is a server firewall-type message that has blocked a specific HTTP post request that contains the keyword "user".
The URL is:
David
6 REPLIES 6
spark43
Re: CCGI Webspace DataTables Warning
@bobpullen Does the support ID : 10457433133417308270 mean anything to you or your friends at Hostopia?
David
bobpullen
Fixes: 316
Yeah, it will be a web application firewall returning that error.
I've raised it with our hosting partner (ref: 5229134), although it's worth me mentioning that I've had limited success in the past in overcoming issues like this.
bobpullen
Fixes: 316
@spark43 would you be willing to create an admin user for your site and share the login credentials (in private obviously) so our hosting partner can try replicating the issue?
spark43
@bobpullen I just noticed I can access User Administration again.
Do you know what the fix was?
bobpullen
Fixes: 316
@spark43, I don't specifically however I've just received a note from our partner to say they believe the problem to be resolved.
spark43
@bobpullen thanks Bob, everything's working again.
