CAnnot delete file called ().dat
- Everything else
- CAnnot delete file called ().dat
04-04-2011 6:44 PM
Ive managed to create a file called ().dat on my webspace and I cant delete it, Im getting a 550 error when I try.
Any ideas how I might get around this?
Message 1 of 4
(985 Views)
3 REPLIES 3
Re: CAnnot delete file called ().dat
04-04-2011 11:46 PM
Will it let you rename the file to (say) a.dat? Then delete that?
David
Message 2 of 4
(419 Views)
05-04-2011 12:59 AM
Can you enclose the filename in single quotes when selecting it for deletion - '().dat'
Message 3 of 4
(419 Views)
05-04-2011 3:12 AM
do these files carry attributes? if so, changing the attribute might allow you to delete.
Message 4 of 4
(419 Views)
- Everything else
