Blocked Site question
Bamboozled
Fixes: 4
Hi
I am trying to access Polecompare.com (to read Fishing Pole reviews) but recently it shows me a Page saying it has been block and has the Text "pn_tasteless"
I also seem to get the options to change that decision via Plusnet but have failed to manage to get any of them done
Anyone got any advice please
Regards
5 REPLIES 5
Fixes: 1,474
Re: Blocked Site question
do you use SafeGuard?
MasterOfReality
Fixes: 57
Hi @Bamboozled
@dvorak has a good point here - can you let us know if you have Safeguard activated on your connection?
Thanks,
MoR
Bamboozled
Fixes: 4
Hi
Thanks for the reply and sorry about late reply
I did not know what "Safeguard" was tbh and had to look - and yes I have it turned on without knowing it - so - is that the root of my problem please ?
To be fair I dont know how a Site "get blocked"
Pornography I can understand but a non contentious one such as Pole Compare is a strange one
Cheers Bamboozled
Mads
Fixes: 79
Hey @Bamboozled,
Thanks for getting back to us.
That may be the cause of the issue, I would suggest going through the Safeguard options and whitelisting the website you wish to browse.
Give us a nudge if this doesn't fix the issue.
Thanks.
Bamboozled
Fixes: 4
Hi again
Yes have changed Safeguard to allow Polecompare and I can now "get it" ok
Knew nothing of Safeguard till today and didnt know therefore how to invoke it
I do now and will be aware if this happens again so many thanks for helping me solve the problem
Cheers bamboozled
