Before I raise a ticket ...
- Everything else
- Re: Before I raise a ticket ...
03-09-2009 10:02 PM
I have a few questions about PN hosted domains.
1) Can I keep them with PN as the registrar, but change the DNS servers registered with Nominet?
2) In requesting the change can I provide the IP addresses to PN to give to Nominet for the NS Glue?
3) Can I also provide the IPv6 addresses of the servers to give to Nominet for the NSv6 Glue?
If the answer is yes to all 3, can I reference this post in my ticket?
Cheers.
A.
Cheers.
A.
Message 1 of 6
(2,095 Views)
5 REPLIES 5
04-09-2009 7:08 PM
I think the answer to 1 is no, so the answer to 2 will be no as well, plus the answer to 3 will be no as well.
Message 2 of 6
(635 Views)
04-09-2009 7:20 PM
I was suspecting as much, since there doesn't seem to be an option anywhere to change the registered DNS servers on the free domains.
123-reg do offer the ability to change the IPv4 glue online, I'll ticket their support and see if they can push through an update that includes the IPv6 glue as well.
If not ... its off to find a cheep registrar that can do the IPv6 glue.
Message 3 of 6
(635 Views)
04-09-2009 9:32 PM
Move it to 123-reg problem solved.
Message 4 of 6
(635 Views)
10-09-2009 6:11 PM
Quote from: Midnight I think the answer to 1 is no, so the answer to 2 will be no as well, plus the answer to 3 will be no as well.
That's a fair assumption.
Message 5 of 6
(635 Views)
28-05-2010 1:35 PM
Apologies for the image but ...
[strike]It appears that http://www.fasthosts.co.uk will allow you to set IPv6 (AAAA) glue records for .co.uk domains, whilst being a resonably priced registrar and free host/free control panel for management.[/strike]
Fasthosts failed to deliver, http://www.hexonet.net, whilst having a bit of an odd interface, do allow this.
Message 6 of 6
(636 Views)
- Everything else
