BTC Mining, port 3333 is closed
- Everything else
- Re: BTC Mining, port 3333 is closed
05-11-2025 11:02 AM
Hey,
I have recently moved to Plusnet and im having issues with ' Network Status Abnormal'. I have reached out to Bitmain and they have said its my port 3333 is closed. Does this sound correct? and how do i open it?
05-11-2025 11:15 AM
What research on the issue have you done?
A google search produced this amongst numerous other discussions ... BItcoind/P2Pool What am I doing wrong? - Bitcoin Stack Exchange
05-11-2025 11:31 AM - edited 05-11-2025 11:40 AM
The Hubs inbuilt firewall allows all outbound traffic, unsolicited in bound traffic is blocked by default.
So, if port 3333 is an outbound connection then the routers firewall will allow the traffic.
However it the connection is an unsolicited inbound connection or the firewall is blocking the connection then you will need to set up a Port Forward rule for TCP to the device which is used for BTC Mining.
To setup a Port Forward rule on the Hub 2 navigate
>Home >Advanced settings >Firewall >Port Forwarding
The rule would look something like
Hope this helps
EDIT: you can check if a port is open on your Hub by using this site https://www.canyouseeme.org/
05-11-2025 11:51 AM
05-11-2025 11:52 AM
Thread moved from Broadband to Everything Else
05-11-2025 2:58 PM
What device do i select?
05-11-2025 3:36 PM
The device that is running the BTC mining app
05-11-2025 3:40 PM
Ive put the ip adress in but still no luck. I can ping the site too. I really dont think the is a connection issues ;/
05-11-2025 4:15 PM - edited 05-11-2025 4:18 PM
To clarify,
For the port forward rule you add the computer/device name or IP Address which is on your home network not the remote site you are connecting to.
Edit: I think you need to refer back to the apps support, maybe adding a port forward rule is not required.
I can't say for sure I do not use BTC
05-11-2025 4:24 PM
It was an issue with the Pooling Site, somehow my Miners worker name had been removed. Anyway after 7 days im back up and running. Really do love how people have helped me on here ![]()
05-11-2025 4:29 PM
Pleased you're back on-line.
If you created a port forward rule then I would suggest removing it if it is not required.
- Everything else
