BT sports app on Fire tv
djh22
Fixes: 5
The BT sports app on Fire TV isn't working at all, just hangs on connection screen. Any ideas please.
6 REPLIES 6
Re: BT sports app on Fire tv
Have you tried force stopping the app and clearing the cache, before restarting the app? On a Firestick, that would be in Settings > Applications > Manage Installed Applications. I don't have a Fire TV, (or BT Sport!), so I don't know if it is the same?
Also, have you tried unplugging the TV at the mains for a couple of minutes and trying again?
djh22
Fixes: 5
Thanks Mr_Paul, yes I've tried all of that and no change, I have 2 Firesticks with same problem on each, so fault at their end I reckon.
willcutforth
Fixes: 113
Hey there @djh22 sorry about the issues you're having. I've had a look at the line and that's fine. Have you split the bands on the wifi of your router?
 Will Cutforth
djh22
Fixes: 5
Hello Willcutforth, thanks for that but no haven't made any changes to router at all.
djh22
Fixes: 5
Ps The app is working ok on both my Android tablets and I can cast ok.
djh22
Fixes: 5
Good morning everyone, I'm delighted to report that the BT sport app on the Firestick is working again after I reinstalled it this morning.
Thanks for your comments.
