BT Wholesale broadband speed test not working
- Everything else
- Re: BT Speed test wonked
18-05-2020 11:13 AM
Just an update, tried it on imac with firefox, worked ok.
18-05-2020 11:24 AM
Just tried it on IOS (iPhone) with safari and still zero upload speed.
I'll try some other Browsers.
18-05-2020 11:34 AM
Oops forgot to add, only down-speed displayed, up-speed 0Mbs on the firefox test.
18-05-2020 12:43 PM
Been like that since last Thursday 0Mbps upload and if you do additional diagnosis it reports that no fault found. If you report the problem with P/N (they use this data for faults) they say report the problem to BT. However on the additional diagnosis page question 8
Q8. What should I do if I have difficulty running the Broadband Performance Tester?
A8. If you have any difficulties in running the tester then please contact your Broadband Provider.
19-05-2020 10:09 AM
For months the previous version of the BT speed tester used to display what seemed to be an accurate download speed, but a totally fictitious upload speed (i.e. higher than is theoretically achievable by ADSL2+)
The new version still seems to register the correct download speed, but an equally fictitious upload speed (0 Mbps) on both tests.
So, still rubbish, but prettier! 😁
(Chrome/Win10)
22-05-2020 11:19 AM
Upload Speed has returned this morning!
22-05-2020 1:36 PM
Blimey, so it does - gonna take a screenshot just in case it's a BTW special offer for one day only! 🤔
22-05-2020 2:00 PM
Thought about that but did not want it to be broken again.
22-05-2020 5:50 PM - edited 22-05-2020 5:51 PM
Yipee get 83Mbs dl on Safari with attenuation of 32Mbs ![]()
Oh, only 20Mbs on Firefox 😞
Still look on the bright side, I get an upload speed greater than zero.
Should I move to BT when my PusNet contract is over?, Answers on a beer map !!
07-06-2020 4:14 PM
The BT speed test does not work on Safari see here: https://www.fasterbroadband.co.uk/guides/bt-broadband-speedtester
It will work and be more accurate if you use Google Chrome
07-06-2020 4:22 PM
Works fairly well on Firefox - and I don't get the warning mentioned in the link.
07-06-2020 4:26 PM
Thanks for that.
More fool BT then, yet another Apple hating site.
Google Chrome, no thanks, rather eat slugs!!
07-06-2020 4:35 PM
Completely agree, but on this occasion its worth using. 😂
07-06-2020 4:38 PM
I think that's Firefox on Mac that has the security issue. What version are you using?
07-06-2020 4:45 PM
FF on W7 - which explains it!😉
- Everything else
