BT Basic With Plusnet
Blade0890
Hello
I have been looking online and there seems to be no clear answer to this question,
If you have a BT Basic Phone Line can you then order Plusnets Broadband Only Package and if so is there restrictions on ADSL or Fibre. Is there anyone currently who does use this setup or something similar.
7 REPLIES 7
Fixes: 1,483
Re: BT Basic With Plusnet
Moderators Note
This topic has been moved from Fibre to Everything Else
Legend
Fixes: 255
Welcome to the forums, @Blade0890 . In answer to your question, and maybe things have changed in the many years since I joined PN, BT Basic is incompatible with broadband services - I'm going back to the days when you had 56kbps dial-up access though.
Fixes: 1,483
You can get it with BT https://btplc.com/Inclusion/ProductsAndServices/BTBasic/BTBasicBroadband/
Blade0890
Thanks for your reply
What I was hoping you could do was have the BT basic landline and then take a Plusnet broadband only package,
Warwick
Fixes: 29
Hi @Blade0809
Thanks for your question.
Unfortunately BT Basic is not a product that we can support as this is a BT stand alone product, as a result it is listed as an incompatible product with any of our services which will cause any orders place to reject.
Sorry if this wasn't the response you were hoping for, let us know if you need any further assistance.
Blade0890
Thank you for the information
MasterOfReality
Fixes: 57
No worries @Blade0890
If we can ever be of more help please do not hesitate to get in touch.
Kind Regards,
MoR
