Are directory names somehow vetted?
- Everything else
- Re: Are directory names somehow vetted?
15-05-2008 10:46 PM
The address i'm trying to reach is http://www.agedhippy.plus.com/hermes/virgin/virgin_index.html - but all i get is the message:
Quote e5
Forbidden
You don't have permission to access /hermes/virgin/virgin_index.html on this server.
0
Is it because i have badly-formed the links? am i missing something obvious? or is the word "virgin" somehow forbidden?
Any guidance will be greatly appreciated.
Incidentally, the "virgin" referred to is a work named "The Virgin of the World" it is a Hermetic work - with no sexual content whatsoever.
Edited to add:
Incidentally, i use Firefox, but i've also tried it with Konqueror, Flock, and Iceape - with the same result.
15-05-2008 10:55 PM
Also make sure the permissions on the virgin directory are 755 and on the file itself.
Finally, create a blank index.html file and put it in each of the directories you don't have an index file in to stop the directory listings occurring allowing others to see exactly what you have in your webspace.
15-05-2008 11:18 PM
http://www.agedhippy.plus.com/hermes/x/
you do get a 403 error on these files
[DIR] Parent Directory 15-May-2008 23:10 -
[TXT] virgin_1.html 15-May-2008 21:33 41k
[TXT] virgin_2.html 15-May-2008 21:33 12k
[TXT] virgin_3.html 15-May-2008 21:33 18k
[TXT] virgin_books.html 15-May-2008 21:33 18k
[TXT] virgin_definitions.html 15-May-2008 21:33 22k
[TXT] virgin_fragments_h-a.html 15-May-2008 21:33 15k
[TXT] virgin_fragments_h-t.html 15-May-2008 21:33 30k
[TXT] virgin_fragments_various.html 15-May-2008 21:33 9k
[TXT] virgin_intro.html 15-May-2008 21:33 31k
[TXT] virgin_system.html 15-May-2008 21:33 25k
[TXT] virgin_treatise.html 15-May-2008 21:34 80k
[TXT] virgindex.html 15-May-2008 21:40 4k
[TXT] x_index.html
15-05-2008 11:24 PM
I can access it with no problem using Konqeror as an ftp client (the way i upload stuff), but even if i copy-and-past the address into Firefox, i get the "Forbidden" message.
Permissions are - as far as i can see, the same as the other directories:
"Owner can View and Modify Content
Group can View Content
Others can View Content."
I should have re-loaded the page, shouldn't i.
15-05-2008 11:32 PM
Quote from: samuria Unless you have changed it since the last post there isnt a directory virgin the virgin files are in
[TXT] x_index.html
Thanks for that.
I'd changed it to try an experiment -- which didn't work.
If the word "virgin" is the problem i can't change the name of the treatise, it is - after all - a major work.
I shall have to dream up some alternative options tonight.
16-05-2008 12:01 AM
of Hermes Mercurius Trismegistus
Translation: A. Kingsford, E. Maitland.
[1884]
Introductory Essays and Preface"
16-05-2008 12:06 AM
Everyone except the owner was "Forbidden", so i've reset them all to "Can Read", and the problem is cured.
Thank you all for your help.
16-05-2008 8:15 AM
[Moderator's note by Jonathan (chillypenguin): Large image file removed, and thumbnail added. Please don't post large images as not all users enjoy fast connections. ]
16-05-2008 1:53 PM
any idea 'what or if' they represent?
16-05-2008 3:13 PM
If not please can we keep things on topic.
Jonathan
aka Chilly
16-05-2008 3:23 PM
It had occurred to me that it was censorship by Plusnet, but that was just paranoia on my part.
One of life's little mysteries....
I thank you all for your input.
16-05-2008 3:32 PM
Very loosly, the web site in question was about the first of my pictures, I was wondering if he knew where the others came from
Wasnt trying to go off topic
16-05-2008 4:06 PM
Back on broadband now, so images are downloading faster too.
16-05-2008 5:36 PM
Quote from: pierre_pierre @Chilly
@ pierre_pierre,
The first of your pictures, if that's the one at the bottom of your first post (No. 7) it is unfamiliar to me.... the image which appears on the index page of "The Virgin of the World" is an Egyptian statue of Isis feeding Her son Horus (a prototype Madonna and child).
The others you posted are also unfamiliar to me....
16-05-2008 6:20 PM
- Everything else
