Apache website hosting problem
- Everything else
- Re: Apache website hosting problem
09-01-2008 10:09 PM
Hi all
I bought a .co.uk domain name, changed name servers to everydns.net and created an A record to point my domain to my PlusNet IP address, waited 48hrs, checked nic.uk that replication had completed and updated the apache.conf file on my (Linux-based) QNAP TS-109 Pro NAS:-
NameVirtualHost *:80
<VirtualHost *:80>
ServerName http://www.domain1.co.uk
ServerAlias domain1.co.uk
DocumentRoot "/share/Qweb/domain1"
</VirtualHost>
But when I enter my website (or IP address) from home I get my home router configuration webpage, instead of my website! And I get "page cannot be displayed" from work.
Do I need to setup a port forwarding rule? Well I forwarded port 80 to the IP address of my TS-109 Pro but it made no difference at all.
Also, when I browse to the IP address of my TS-109 Pro, I get /share/Qweb/domain1/index.htm.
Any ideas where I am going wrong please?
Scott
_________________
QNAP TS-109 Pro version 1.1.4 build 1207T
1TB Hitachi Deskstar HDS721010KLA330
BT Voyager 210 ADSL router
APC Back-UPS ES 700VA
Vista Ultimate 32-bit
<VirtualHost *:80>
</VirtualHost>
Scott
_________________
Message 1 of 6
(6,796 Views)
5 REPLIES 5
09-01-2008 10:51 PM
First the problem accessing from your internal network. This will not work because most routers get confused if you try to use your routers external IP address internally and assume you are trying to access it internally so show the config screen. You need to set-up an entry in your hosts file for the domain name (and any sub-domains) to point to the internal IP of your webserver. So when you put www.domain.com in your browser, your local PC will use your internal IP address rather than the external one via a DNS lookup.
For your problem accessing it via work. You do need to forward port 80 on your router to the internal IP address of your web server.
Finally the conf file is wrong. http:// is never passed to the web server, it is used by the browser to determine the protocol it should use to connect with the URL given (http ftp etc). Try:
ServerName domain1.co.uk
ServerAlias www.domain1.co.uk
DocumentRoot "/share/Qweb/domain1/"
And remember to restart the apache service so it re-reads the conf file
Also you can try using httpd -S to verify the config file and any virtual Hosts defined. I suspect Apache may not actually be running if it detected a conf file error. Check the apache logs.
Message 2 of 6
(866 Views)
09-01-2008 11:19 PM
Thanks for the prompt and helpful reply, Peter!
1) I have mapped the IP address of the NAS to my domain name in the C:\Windows\System32\drivers\etc\hosts file. I now get an error when accessing my website internally "The requested URL / was not found on this server. Apache/1.3.37 Server at www.domain1.co.uk Port 80"
2) I have forwarded port 80 to the IP address of the NAS (i.e. web server) and will test from work tomorrow morning.
3) I have updated the apache.conf file as per your advice.
4) I have restarted the apache service using "/etc/init.d/Qthttpd.sh restart"
5) How do I run the Httpd -S command? I am getting to grips with WinSCP (Commands --> Open Terminal) and can restart the apache service ok but am not an Apache/Linux guru so struggling how to do this. Any ideas please?
6) The apache_access_log is empty, but the apache_error_log reads "[Wed Jan 9 23:02:37 2008] [alert] apache: Could not determine the server's fully qualified domain name, using 192.168.*.* for ServerName
[Wed Jan 9 23:02:37 2008] [crit] (98)Address already in use: make_sock: could not bind to port 80"
Any further help would be most appreciated.
Many thanks
Scott
Many thanks
Scott
Message 3 of 6
(866 Views)
09-01-2008 11:28 PM
I'm not familiar with QNAP so can't really help as it looks like it may be using a modified apache install.
Normally from the shell prompt ($ or more likely # for root) on a Linux box you just run httpd -S where httpd is the apache binary but if the QNAP uses a different name for httpd that will not work.
If you have access to a shell prompt on the QNAT try ps xa to get a process listing and see if there are any httpd or similar programs running, then use that in place of httpd. It may actually be called qthttpd so try qthttpd -S.
You need to get it working when accessing internally before it is likely to work externally.
Message 4 of 6
(866 Views)
09-01-2008 11:59 PM
ps xa worked fine from root and displayed the following:-
PID Uid VmSize Stat Command
1 admin 540 S init
2 admin SWN [ksoftirqd/0]
3 admin SW< [events/0]
4 admin SW< [khelper]
5 admin SW< [kthread]
11 admin SW< [kblockd/0]
14 admin SW [khubd]
51 admin SW [pdflush]
52 admin SW [pdflush]
54 admin SW< [aio/0]
53 admin SW [kswapd0]
56 admin SW [cifsoplockd]
184 admin SW [scsi_eh_0]
185 admin SW [scsi_eh_1]
198 admin SW [mtdblockd]
277 admin SW [kjournald]
287 admin 624 S /sbin/daemon_mgr
336 admin SW [kjournald]
375 admin SW [kjournald]
400 admin 668 S /sbin/hotswap
404 admin 848 S /sbin/hd_util
413 admin 848 S /sbin/hd_util
414 admin 848 S /sbin/hd_util
422 admin 848 S /sbin/hd_util
508 admin 1784 S /usr/local/sbin/thttpd -p 8081 -nor -nos -u admin -d
523 admin 6940 S /usr/local/apache/bin/apache
524 guest 7092 S /usr/local/apache/bin/apache
525 guest 7092 S /usr/local/apache/bin/apache
526 guest 7088 S /usr/local/apache/bin/apache
527 guest 7088 S /usr/local/apache/bin/apache
528 guest 7092 S /usr/local/apache/bin/apache
543 admin 2828 S /usr/local/samba/sbin/smbd -l /var/log -D -s /etc/con
544 admin 2820 S /usr/local/samba/sbin/smbd -l /var/log -D -s /etc/con
547 admin 2232 S /usr/local/samba/sbin/nmbd -l /var/log -D -s /etc/con
554 guest 2988 S proftpd: (accepting connections)
565 admin 1004 S /sbin/btd
574 guest 772 S /sbin/ImRd -d
584 admin 640 S /usr/sbin/crond -l 9
607 admin 664 S /usr/sbin/ntpdated
613 admin 1504 S /usr/sbin/stunnel /etc/stunnel/stunnel.conf
628 admin 596 S /sbin/recycled
668 admin 772 R /sbin/apcupsd -f /etc/apcupsd/apcupsd.conf
683 admin 1412 S /usr/sbin/sshd -f /etc/ssh/sshd_config -p 22
696 admin 452 S /mnt/HDA_ROOT/twonkymedia/twonkymedia -inifile /mnt/H
697 admin 2240 S /mnt/HDA_ROOT/twonkymedia/twonkymediaserver -inifile
709 admin 2240 S /mnt/HDA_ROOT/twonkymedia/twonkymediaserver -inifile
710 admin 2240 S /mnt/HDA_ROOT/twonkymedia/twonkymediaserver -inifile
711 admin 2240 S /mnt/HDA_ROOT/twonkymedia/twonkymediaserver -inifile
712 admin 2240 S /mnt/HDA_ROOT/twonkymedia/twonkymediaserver -inifile
713 admin 2240 S /mnt/HDA_ROOT/twonkymedia/twonkymediaserver -inifile
714 admin 2240 S /mnt/HDA_ROOT/twonkymedia/twonkymediaserver -inifile
715 admin 2240 S /mnt/HDA_ROOT/twonkymedia/twonkymediaserver -inifile
723 admin 1076 S /sbin/bcclient
724 admin 1076 S /sbin/bcclient
725 admin 1076 S /sbin/bcclient
734 admin 1076 S /sbin/bcclient
747 admin 792 S /sbin/picd
751 admin 728 S /sbin/gpiod
763 admin 892 S /usr/bin/rsync --daemon
764 admin 772 S /sbin/apcupsd -f /etc/apcupsd/apcupsd.conf
765 admin 772 S /sbin/apcupsd -f /etc/apcupsd/apcupsd.conf
833 admin 504 S /sbin/getty 115200 ttyS0
863 guest 7092 S /usr/local/apache/bin/apache
864 guest 7092 S /usr/local/apache/bin/apache
875 guest 7092 S /usr/local/apache/bin/apache
876 guest 7092 S /usr/local/apache/bin/apache
901 admin 3268 S /usr/local/samba/sbin/smbd -l /var/log -D -s /etc/con
925 admin 2156 S /usr/sbin/sshd -f /etc/ssh/sshd_config -p 22 -R
926 admin 1036 S -sh
982 admin 628 R ps xa
I couldn't find Httpd but I did try "thttpd" and "Qthttpd", although without any success:-
/usr/local/sbin$ thttpd -s
-sh: line 69: thttpd: command not found
-sh: line 71: thttpd: command not found
/usr/local/sbin$ Qthttpd
-sh: line 73: Qthttpd: command not found
/usr/local/sbin$ info Qthttpd
-sh: line 75: info: command not found
1) Any ideas on where I go from here with the "httpd -S" command?
2) Well thx to you, I now have www.domain1.co.uk working internally. Should I assume that now I have forwarded port 80 to the web server www.domain1.co.uk should also work externally?
Scott
1 admin 540 S init
14 admin SW [khubd]
Scott
Message 5 of 6
(866 Views)
10-01-2008 12:30 AM
Just remotely connected to work and tested website works perfectly!
That just leaves me to thank you Peter!
Much appreciated!!!
Scott
Much appreciated!!!
Scott
Message 6 of 6
(866 Views)
- Everything else
