Anyone used DotNetNuke software?
- Everything else
- Anyone used DotNetNuke software?
25-09-2007 1:56 PM
hi
Can anyone enlighten me? Can I use DNN on plusnet? If so, might need a few pointers, much appreciated!!!
hi
Message 1 of 3
(2,279 Views)
2 REPLIES 2
Re: Anyone used DotNetNuke software?
25-09-2007 6:24 PM
I've not heard of this software before so I had to look it up. Unfortunately, it will not run on Plusnet servers because it requires a Windows hosting environment including ASP.NET and SQL Server.
Unfortunately, Plusnet only provide PHP and MySQL on the ccgi server, so you can't host it there. You could use phpNUKE, Mambo or Joomla on the ccgi system, and you can find tutorials for installing some of those CMS systems here.
Message 2 of 3
(334 Views)
25-09-2007 6:29 PM
Message 3 of 3
(334 Views)
- Everything else
