Any suggestions for a plain text editor?
- Everything else
- Any suggestions for a plain text editor?
06-08-2008 9:21 AM
A text editor. A decent one, not notepad or MS word in text mode but something along the lines of BBedit on a Mac, that offers tag balancing, regex find/replace, the ability to turn text wrap off etc. Built in FTP would be useful but not essential.
A visual webpage editor. A sort of "dreamweaver very light". Nothing flash, but something that will do simple layout, understands CSS, outputs clean code and offers a switch from layout to code view. I normally use Dreamweaver, but it's overkill for this (and the budget!). It's mainly for generating snippets of code quickly, not laying out whole pages.
I'll only be using it for a short while, so I'm looking for options that are reasonably inexpensive, probably shareware.
Any suggestions for personal favourites you have experience of would be much appreciated.
Re: Any suggestions for a plain text editor?
06-08-2008 9:35 AM
06-08-2008 11:38 AM
09-08-2008 7:50 PM
09-08-2008 7:53 PM
09-08-2008 9:11 PM
For WYSIWYG I use the old Netscape composer. http://www.seamonkey-project.org/ ; It's kept alive by the Sea Monkey project.
This maybe an overkill for you are doing but you could try this http://www.aptana.com/ ; Its a full IDE. I uninstalled it because it was too bloated for my use and it messed with my file associations.
09-08-2008 10:20 PM
Edit: Decided after writing this that I was just being a little TOO lazy, so i've removed MS Notepad and replaced it completely with Notepad++ - same method of starting, yet it starts a much better editor.
10-08-2008 12:43 PM
I use Notepad 2 on Windows, does everything I need.
Doesn't fill the OP's original Specificaion for RegExp Searches.
As for (S-)FTP, I use WinSCP.
I like it particularly because it allows quick access to PuTTY,
when using an S-FTP Session it can save a lot of hastle & time!
As for a "Dreaweaver but Very Light", bound to be something which does what you want but I wouldn't know where to look.
I just use my Browser and a Local Web Server / Work directy on my Webspace and backup regularly.
With respect to creating a CMS, security is a must have for any dynamic content.
My website has caught 61 exceptions which consist of: SQL Injection, bad XSS atempts and string termination.
Nothing has got through so far
@MikeWhiteHead: Syntax Highlighting can save hours worth of Hair Pulling.
If you're a well practiced developer it may not be a necessity but can be a useful visual aid.
Jim,
10-08-2008 12:48 PM
PHPdesigner2007 personal
Ignore the PHP naming, it also handles CSS, Javascript, C++,HTML A nice simple to use tool.
There is also the newer 2008 version available as a trial download - but a paid for option - no personal version
10-08-2008 3:11 PM
13-08-2008 1:28 PM
Quote from: paulh i use a DOS port of vi ... but then i'm not quite right in the noodle
vi is made out of win though. I do prefer vim however for it's syntax highlighting and better usability.
13-08-2008 5:56 PM
13-08-2008 7:01 PM
13-08-2008 7:18 PM
Quote from: Ben vi is made out of win though.
i have no idea what that means ...
14-08-2008 11:49 AM
Customer and Forum Moderator. Windows 10 Firefox 87.0 (64-bit)
- Everything else
