Amazon echo Dot doesnt let me setup calling
FIXED- Subscribe to RSS Feed
- Everything else
- Amazon echo Dot doesnt let me setup calling
01-07-2020 7:34 PM
I have tried many times seting up Alexa calling on my echo but it doesnt let me text ALEXA to 150. You may be thinkig that that is to setup EE but my reaserh suggests that Plusnet uses the EE data lines. I have searched the internet for other who have this problem but they either have not got the Plusnet service or they are sorting something else out.
Please could you give me an answer to weather it is avaliable on Plusnet or point me in the right direction to finding an answer.
Fixed! Go to the fix.
01-07-2020 8:41 PM - edited 01-07-2020 8:41 PM
Plusnet do use the EE network but they dont provide all the services that EE may. Alexa calling is one that's not provided AFAIK
Re: Amazon echo Dot doesnt let me setup calling
01-07-2020 11:00 PM
Bit confused here, is your Echo connected to your internet?
I don't believe echo calling goes via the mobile phone network.
As an experiment I switched my mobile to Airplane mode and asked Alexa to call my landline, which it did.
However Alexa says text is not supported, so what is it you are trying to do?
02-07-2020 10:18 AM
- Everything else
