After Greenby switch, Can't update website
Ray5
Re: After Greenby switch, Can't update website
There may be an issue with my (old) account - I have an original account which comes with a fixed IP.
<redacted> is my fixed IP.
The resolution of <redacted> will hit the outside of my router.
All I want to do is be able to FTP to whereever the files that
<Redacted>
are pointing at.
I assume the current FTP sites are still pointing at the old F9 space, which isn't the greenby webspace.
Yes, the difference with/without the www was handy for me, to differentiate between my F9 webspace and whatever I decided to do with my own IP.
Moderator's note:
Personal information removed from a public forum (to an area that staff can see).
Fixes: 245
Ooops!
Should have done that check on my desktop not my phone or do Kate!  I’ve mistaken that 212.159 IP address as being homepages.plus.net - thus confusing routing as we’ve seen before..
FTP.plus.net points to the Greenby proxy … so if that does not know where your service is (correctly) then your updates could be going to the wrong environment.
Ray5
This issue is unchanged.
Does anyone know how to raise a ticket for getting it resolved?
thanks
Ray5
I just checked again today and it's magically working.
