Advice for best way to do a seamless VOIP port when moving to full fibre
Stephenhowes
I'm getting an upgrade to full fibre with Plusnet later this month and since Plusnet don't provide a VOIP service (puzzling) I am looking to go to another provider (probably A&A) for VOIP.. I thought that the smart thing to do would be to setup VOIP now and to do the number port early but apparently if I do then my existing BB service will be ceased and the order for the new full fibre will be cancelled!!!..... This is a crazy situation if this is correct.
So, can anyone explain please in a step by step way what is the most effective/safest way to do the FTTP upgrade  and number port without  undue disruption to the landline service. (Or at least minimal)
The only thing I can think of is to see if the new VOIP provider can do the number port on the same day as the planned FTTP install but there is an element of risk if the FTTP upgrade gets delayed at the last minute.
Surely there must be sensible process for doing this.....I've worked in IT for 40 years so can hopefully work my way through this but your average customer doesn't  stand a chance and will leave Plusnet for someone who can provide a full seamless service, in which case I wonder what the future is for Plusnet.
Steve
Tags (1)
17 REPLIES 17
crowroad
Re: Advice for best way to do a seamless VOIP port when moving to full fibre
According to Ofcom's general conditions relating to number portability, ALL providers are required to quarantine a ceased Landline number for AT LEAST 31 days before returning it to the original owner of the number range.
Consequently, on the day the the full fibre is made operational, the landline will be ceased, and you then have 31 days to arrange with a willing VOIP SP to port your landline number to their VOIP network, and from then on you OWN that number, and can port it again to any other VOIP provided you wish, subject to contract.
However, do I think that PN has succient recognition of this requirement to assiste people like you and me - no I don't.  Such a number port would take 4-6 working (with eg A&A) or more, so assuming that the FF upgrade completes in less than that time, the number port to VOIP can proceed minimising the down time, but it may be wiser to wait until it is recorded as at least operational.
Good luck.  Hope you don't have to retain a Static IP number as well.
Fixes: 1,491
Moderators Note
This topic has been moved from Full Fibre to Everything Else
Fixes: 87
@Stephenhowes
As far as I know, the best way is to set up your VOIP account in advance and then port the number out as soon as you have FTTP up and running. There will be a few days downtime.
Make sure you have your phones sorted for VOIP - but an ATA if required in advance.
Stephenhowes
Agree, this is less than an ideal situation...I've been a happy PN customer for many years and have referred a number of people but I think we have been very let down here. I'm the go-to person for a number of people in the village when it comes to IT and  many locals are doing the FF switch now and if they still want a land line I will sadly be suggesting they go elsewhere.
I'd forgotten about my static IP ... blast!
Steve
Stephenhowes
Thanks Brian,
I've dusted down an old Cicso ATA which I'll use... I've signed up with A&A and am currently testing with a number which I'll ditch when I do the port.... (New ATA's at a decent pricepoint seem to be hard to come by at the moment.)
PN have really shot themselves in the foot here IMO
Steve
Fixes: 87
@Stephenhowes
Your Static IP should not change and there should be little downtime on the your Internet connection.
If you leave PN then you lose any referrels and your e-mail.
Down time on the phone is your only option unless you want to move to an ISP that does both.
Edit : You at least would have a phone line once you get your FTTP up and running - just no incoming calls.
Fixes: 527
PN are not actually involved in number porting. They ( together with Bt retail & EE ) operate under the BT group CUPID ( Communications provider ID ) so all porting is handled by the BT number porting team. I'm reliably informed that they do understand and comply with Ofcoms latest requirements to port for up to 31 days after ceasing. This is confirmed by a number of posts on here of successful ports. AFAICS  the only problems we've seen have been some voip suppliers not attempting ports when they see the number as not active.
greygit1
There's a cats (possibly named after networking tech rather than felines?) team in Plusnet who (apparently) are the only team who can directly interface/communicate with BT.
Sounds like there's a lot of changes behind the scenes?
crowroad
Well, the problem with PN is that their Sales/Upgrade staff, for the most part, don't seem to have that knowledge.  If you ask them, as I did only on Monday of this week: Can you please confirm (should anything go wrong), that my landline number will be quarantined for at least 31 days after my Full Filbre upgrade is operationa, so that I can arrange to have my number ported (to A&A), I, at least, got told they didn't know anything about any of that.  That's part of the problem, so people are left to 'hope for the best'.
Sure, once I insisted I asked this question of PN technical team, I got the confirmation about the quarantine I needed, along with some useful suggestions about how long the window might actually be in practise.
As for other issues, such as Static IP, look in this thread for my very recent experience. 🙂
crowroad
Well,  I wish I could be sure this is the case.  I do not deny that others have had this experience, and this is becuase the static IP address is assosciated with the user account (allocated to that user), and the router using e.g. a Radius server, is allocated that address when it makes it's DHCP request.
Or so I had been told.  But when I phoned the FF upgrade team on Tuesday, after much 'investigation' on their part, they told me that: a) I had a 'old' account (yes, I've been on PN since April 2013, is that my fault?)
              b) the FF is a 'differernt infrastructure' and can't work with my account.  Why?
              c)  they would need to set up a 'new' account, and I would lose my current static IP address, and get a totally new one.
I am currently awaiting a reply to a complaint ticket asking PN why this is the case, and why they haven't planned to make arrangements to ensure that users do not lose their Static IP addresses, just becuase of a change in the physical infrastructure.
If what I was told was, yet again, ill-informed guidance from the upgrade/sales team, I should be glad to hear so, but so far I have not been informed otherwise.
Fixes: 527
@crowroad Im not sure I would have expected the Sales people to have a full knowledge of the porting process BUT I would have hoped they would point you to the Technical people to clarify. From what you say the technical people did provide the clarification.
Sorry, what were the static IP issues ?
RobPN
Fixes: 13
Well,  I wish I could be sure this is the case. ...
<snip>
... (yes, I've been on PN since April 2013, is that my fault?)
<snip>
@crowroad
I've been with PN since 2002 with the same account, and had (and still have) the same static IP address since Day 1.
During that time I've changed through various flavours of ADSL, then the PN FTTP trial, and finally the retail FTTP product.
RealAleMadrid
Fixes: 66
@crowroad  You said ...." If what I was told was, yet again, ill-informed guidance from the upgrade/sales team,"
You've hit the nail on the head there, as @RobPN has said his even older account has been through many changes without losing the static IP address.
So I believe .... "the FF is a 'different infrastructure' and can't work with my account." is not true.
Let's hope that whoever replies to your ticket has got a clue and sorts your queries out.
crowroad
Glad to hear it.  However, coming up against Sales/Upgrade team members who hve not been briefed on possible questions that users might ask during the Full Fibre ugrade leaves customers bewildered as to who is telling the correct story?  On  person says one thing, another says the complete opposite. As a customer I need to know it would not all end up a disaster of one kind of another.
I didn't make it up, it'll all be on PN's recording of the discussion with me.if they ever get off reading social media, and respond to my complaint.
